- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C6300 stops broadcasting, resets to channel 0 with Samsung Galaxy Book 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
My wife purchased the new Samsung Galaxy Book 12 (wifi plus LTE, from Verizon). We have a Netgear C6300 and the ISP is Time Warner Cable (Spectrum) in New England.
Within 60 seconds of the Samsung connecting to the network, the C6300 stops broadcasting SSID for both 2.4G and 5G wifi networks. Both networks reset to channel 0 (zero). Connecting to either network causes both networks to stop broadcasting. Turning off the Galaxy Book's wifi adapter and resetting the router resolves the problem, but as soon as the Galaxy Book's adapter is turned on and it connects to either network, both networks stop broadcasting and are reset to channel 0.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C6300 stops broadcasting, resets to channel 0 with Samsung Galaxy Book 12
Hello BroadCove
Do you have the latest wifi drivers for this device?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I managed to resolve the issue, but I'm not sure exactly what the solution was. I took the new device (Galaxy Book) to another location and updated all of the software/drivers. When I brought it back home, I was able to connect to the network. Then the C6300 evidenced a new problem: it was broadcasting and I could connect to the wifi, but there was no access to the internet (couldn't even get to the C6300 admin page with an ethernet cable connected directly). Called Time Warner Cable (Spectrum), went through a few things, and ultimately did a hard reset. I had been avoiding that because I didn't want to set up the networks again. But I did, and so far, so good. I'm on 36+ hours of stable connections/internet. Hoping that's the end of it.
