Orbi WiFi 7 RBE973
Reply
C6300 wifi drops after ICMP attack
myhobbscoast
Bought this router last August, since a couple of weeks my wireless drops after I've been attacked. I can clearly connect both events as the affect is immediate, after a restart of the router wireless is back in order until the next attack, which can happen multiple times a day. Pretty annoying to say at least, my internet connection is not affected, as all wired connections remain active after the attack only my 2.4ghz SSID/access point is down (I deactivated my 5ghz and don't use it).. FYI - I factory reset the router but as the router is receiving the same WAN address from Comcast/Xfinity it doesn't make any difference.. any thoughts or ways to configure the router to withstand the attacks and not shutting down my wireless ?
Here some more details:
Hardware Version V3.0
Firmware Version 2.01.14
Provider: Comcast Xfinity
Type of attack: [DoS attack] ICMP flood from
IP addresses attacks have been recorded: 129.82.138.44 // 185.94.111.1 // 203.178.148.19 // 50.135.6.15 // 162.248.167.115 // 198.20.99.130
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 3
netwrks
Master
Re: C6300 wifi drops after ICMP attack
For certain, no consuner grade router will stop a DoS attack. Sounds like it's a bandwidth attack. The router will usually reboot, or hang. Check with your ISP, maybe thay can block those sunbets before they get to you. Check you network devices (phones / laptops / desktops), for any malware or viruses. DoS attacks can start on the host side of the network.
https://en.wikipedia.org/wiki/Denial-of-service_attack
Message 2 of 3
myhobbscoast
Thanks, but this doesn't answer my question how I can resolve it as none of my previous routers had this issue. My ISP is saying its a router/ hardware issue as internet is still up, I've checked my laptop and I don't have any malicious software or virus signs.. Looks like I tanked 250$ for a bad device 😐 looks like Netgear lost its edge a bit.. Very unfortunate..
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4699 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
