- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7000v2 1 bar
- Mark as New
- Bookmark
- Subscribe
- Permalink
C7000v2 1 bar
The router is 1 inch from pc. All cables are tight. No obstructions. Only 1 bar on iPhone
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7000v2 1 bar
Power OFF modem for 1 minute the back ON.
What channels are you using?
Has a factory reset and setup from scratch been performed?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7000v2 1 bar
Yes to everything. I was told that the one bar didn't mean anything. I am using Netgear 80 5G. I don't have any problem other than in my house using wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7000v2 1 bar
Where are you see this 1 bar at?
What channels are you using on the modem?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
