Orbi WiFi 7 RBE973
Reply
C7800 power supply part number
Troach6
Follower
My Power Supply Was Lost During A Move And I need To Purchase Another. Can Someone Get The Part Number For Me Please
Model: C7800|Nighthawk X4S-AC3200 WiFi Cable Modem Router
Message 1 of 2
Re: C7800 power supply part number
Netgear does not sell replacement power adapters. Any generic adapter will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions.
If you search in the usual places, you may find some that say they are compatible with your Netgear device, or a model that has the same power specifications.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 985 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
