JerMajesty's avatar
JerMajesty
CAX 80 Router and ethernet ports not working after reboot
Hello, yesterday I decided to reboot my modem/router due to dropped connectivity. After reboot, the modem showed connection but my router and ethernet ports became inoperable. I tried to reset to factory settings but this did not fix the issue. I reached out to Netgear and they won't help without a minimum payment of $90. I cant access the internet via the router to use the Nighthawk app or hardwire to access settings via the port gateway 192.168.1.1. Can use the USB port to try to push uncorrupted firmware? Will a USB to ethernet cable allow me to access the gateway? I would like to also ensure its not a hardware issue. Any guidance would be great. Thanks.
