Orbi WiFi 7 RBE973
Reply
CAX30 - losing signal every few minutes
mikaelderderian
MODEM-ROUTER purchased from costco in May 2022.
Problem started 2 weeks ago and keeps happening every few minutes.
I work from home and can't have any type of teams or zoom meeting without losing sound every minute for 5-10 sec...
I have performed reset, updated firmware, renamed my wifi networks...
Same problem happens form any device.
My ISP confirmed everything is fine on their end.
I need help urgently.
Thanks
Message 1 of 8
Guru
Re: CAX30 - losing signal every few minutes
Happens on wired devices as well?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-mode...
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Message 2 of 8
mikaelderderian
Thank you so much for the support. I just changed the channels as suggested and issue continues.
Note that I have 3 WIFI neighbors - their network names are very different.
Cable type and setup has not been changed since may when it was working perfectly (issue started couple weeks ago)
Hardware VersionV1.01
Firmware VersionV1.4.10.10
Cable Firmware VersionV1.04.09
Here is the data from the cable connection tab.
Cable Connection
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
<tabindex=-1>Startup Procedure</tabindex=-1>
ProcedureStatusComment
Acquire Downstream Channel675000000 HzLocked
Connectivity StateOKRegistration Complete
Boot StateOKOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDIPv4 only
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectabables
1Locked256 QAM31675000000 Hz-2.-5 dBmV40.4 dB48219
2Locked256 QAM1489000000 Hz0.8 dBmV42.9 dB00
3Locked256 QAM2495000000 Hz0.7 dBmV42.8 dB00
4Locked256 QAM3501000000 Hz0.5 dBmV42.6 dB00
5Locked256 QAM4507000000 Hz0.5 dBmV42.7 dB00
6Locked256 QAM5513000000 Hz0.8 dBmV42.9 dB00
7Locked256 QAM6519000000 Hz0.3 dBmV42.6 dB00
8Locked256 QAM7525000000 Hz0.0 dBmV42.4 dB00
9Locked256 QAM8531000000 Hz0.3 dBmV42.6 dB00
10Locked256 QAM9537000000 Hz0.3 dBmV42.7 dB00
11Locked256 QAM10543000000 Hz0.-3 dBmV41.8 dB00
12Locked256 QAM11549000000 Hz0.-5 dBmV42.0 dB00
13Locked256 QAM12555000000 Hz0.-4 dBmV42.2 dB00
14Locked256 QAM13561000000 Hz0.-1 dBmV42.3 dB00
15Locked256 QAM14567000000 Hz0.-9 dBmV41.2 dB00
16Locked256 QAM15573000000 Hz-1.-4 dBmV41.4 dB00
17Locked256 QAM16585000000 Hz0.-8 dBmV41.9 dB00
18Locked256 QAM17591000000 Hz-1.-5 dBmV41.2 dB00
19Locked256 QAM18597000000 Hz-1.-6 dBmV41.4 dB00
20Locked256 QAM19603000000 Hz-1.-7 dBmV41.5 dB00
21Locked256 QAM20609000000 Hz-1.-9 dBmV41.4 dB00
22Locked256 QAM21615000000 Hz-2.0 dBmV41.2 dB00
23Locked256 QAM22621000000 Hz-2.-4 dBmV41.1 dB00
24Locked256 QAM23627000000 Hz-2.-4 dBmV40.8 dB00
25Locked256 QAM24633000000 Hz-2.-6 dBmV38.3 dB00
26Locked256 QAM25639000000 Hz-2.-9 dBmV37.3 dB00
27Locked256 QAM26645000000 Hz-2.-7 dBmV41.0 dB00
28Locked256 QAM27651000000 Hz-2.-8 dBmV41.0 dB00
29Locked256 QAM28657000000 Hz-3.-2 dBmV40.7 dB00
30Locked256 QAM29663000000 Hz-3.-2 dBmV40.7 dB00
31Locked256 QAM30669000000 Hz-2.-9 dBmV40.8 dB00
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA15120 Ksym/sec21900000 Hz42.3 dBmV
2LockedATDMA25120 Ksym/sec28300000 Hz42.8 dBmV
3LockedATDMA35120 Ksym/sec34700000 Hz44.3 dBmV
4LockedATDMA45120 Ksym/sec39500000 Hz45.8 dBmV
5Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
6Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
7Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
8Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
ChannelChannel IDIndicatorSubcarrier Zero FrequencyActive Subcarrier Number RangeTotal CodewordsUncorrectable Codewords
132Non-Primary611.6 MHz1348 ~ 27471923763170
20Other0 MHz0 ~ 000
ChannelUpstreamIsMutedRanging StatusSubcarrier Zero FrequencyActive Subcarrier Number RangeSymbols Per FrameTx Power
1 Other0 MHz0 ~ 000 dBmV
2 Other0 MHz0 ~ 000 dBmV
Message 3 of 8
Guru
Well power is a bit on the low side but with in specs.
Zeros for Correct and un-correctables.
Has a factory reset and setup from scratch been performed.
Try reducing the WiFi power on the modem from 100% to 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
Can you find out what channels your Neighbors are using?
Set channels 1 and 40 or 11 and 48 or 149 for the wifi radios.
Please post a copy of the Event Logs as well here.
Message 4 of 8
mikaelderderian
Thanks again.
I did change to 50% but issue continues - same for the channels.
Manufacturing reset has been done last week.
I don't have an easy way to get the channel from my neighbors...
Here is the log event:
TimePriorityDescription
2022-09-29 11:44:28Warning (5)REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1;
2022-09-29 11:44:23Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1;
2022-09-29 11:44:22Notice (6)TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1;
2022-09-29 11:44:21Warning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:30Notice (6)Honoring MDD; IP provisioning mode = IPv4
1970-01-01 00:00:24Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:32Critical (3)No Ranging Response received - T3 time-out;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:25Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2022-09-22 17:39:58Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1;
2022-09-22 14:59:21Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:29Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2022-09-21 08:49:51Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1;
Message 5 of 8
Guru
You some Criticals that the ISP needs to review and resolve.
I would have the ISP online with you while checking there logs and signal if they can see the modem go off line...
Message 6 of 8
mikaelderderian
So after weeks doing trouble shooting, having my ISP provider technician checking everything, he confirmed that it was a malfunction from the CAX30. He ultimately demonstrated by replacing with their own equipment - the issue was fixed.
So I went back to Cosco yesterday, bought the same CAX30, swapped with the previous one and now everything works perfectly (with same set ups, names...).
Magic question: how do I activate the warranty on my malfunctioning CAX30 to be reimbursed? It was purchased from Cosco 8months ago.
Thank you for your help
Mikael
Message 7 of 8
Guru
I would ask Costco to see if they would take the faulty unit back for a refund. I've heard Costco is good in this area.
If not, you'll need to contact NG support.
@olympos1625 @DarrenM
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 721 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
