Orbi WiFi 7 RBE973
Reply
CAX80 Speed Issues
jesmith602
Apprentice
CAX80 Speed Issues
I am unable to get my CAX80 faster than 200 down on a wired or wireless connection.
  • I have Cox Gigablast
  • No splitters, amplifiers, or attenuators in line. Using RG6.
  • CAX80 is in router mode.
The modem speed test reports ~500Mbps, but I can't get near to that even when I'm plugged into it. In fact, wireless is faster than being plugged into. Appreciate any recommendations!
CAX80 logsCAX80 logs
Message 1 of 4
Guru
Re: CAX80 Speed Issues
What wired devices are you using? Try a different wired device to compare speeds.
Ensure your using good quality LAN cables. CAT6 is recommended.
Be sure to use Ooklas installable speed test app rather then there web page site.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 4
jesmith602
Apprentice
Yes, I've tested with Ookla using two different laptops connected with CAT6.
Message 3 of 4
Guru
Is Armor enabled by chance?
Anything running on the PCs what could slow down speed tests?
Try a factory reset and setup from scratch then run a speed test again?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 625 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
