Orbi WiFi 7 RBE973
Reply
CM1000 Xfinity - Upload Speeds
Ron-Richardson
Just installed the CM1000 (to wired desktop) and I have Xfinity's 250M down / 10M up.   When I run the Xfinity speed test, I get about 280M / 11M.   That looks great.  Then I upload files via FTP or file upload in cPanel, both to four different hosting services, I consistently get about 1.4M upload speed.  I don't get it...  I really wanted faster upload speeds.  Is it Xfinity?
Model: CM1000|DOCSIS® 3.1
Message 1 of 4
vkdelta
NETGEAR Expert
Re: CM1000 Xfinity - Upload Speeds
is it 1.4MBps or 1.4 Mbps?
It might be cPanel limitation or you need to put multiple transfer threads in the FTP tool.
Message 2 of 4
Ron-Richardson
It's 1.4MB.   Rookie mistake.  And, now I see that speedtests are in Mb.  So, that mystery solved.  I am getting the upload speed that I should.
But, I'm intrigued....  "multiple transfer threads in the FTP" ?   I'm using WinSCP.  Is that a feature of the FTP program or modem?  BTW, on Win 10.
Message 3 of 4
vkdelta
NETGEAR Expert
yes, lot of folks forget MB vs Mb.
not sure if winSCP supports it.
https://winscp.net/tracker/513
you are using SFTP and not traditional FTP.
I believe Filezilla supports using FTP.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1348 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
