Orbi WiFi 7 RBE973
Reply
CM1000v2 and RAX54v2 fluctuating download speeds. I go from 900mbps to 30mbps randomly.
Rydaquin
I've already contacted my ISP and was told that everything is fine on their end. I've switched out all the ethernet cords to no avail. Any help would be much appreciated.
Message 1 of 13
Accepted Solutions
Rydaquin
Re: CM1000v2 and RAX54v2 fluctuating download speeds. I go from 900mbps to 30mbps randomly.
Thanks for the info. I had my ISP come out and they checked and changed the COAX cables. Said I wasn't getting any power and that one of the cables was dead. So far it seems to be working. I'll watch it for 24hr to see if it dips back down or not.
Message 10 of 13
All Replies
Guru
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-mode...
Is this over a wired or wireless connection for these results? Wireless could result in varied results. Wired is recommended.
Do you see same when ethernet connected directly to the back of the CM modem with out the router being online?
Compare with different device or PC to see if same thing is seen there as well.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Message 2 of 13
Rydaquin
Thanks for the quick reply Furry. I am currently at work so I'll get that information once I get home. I have tried bypassing the router but plugging directly to the modem with a cat8, no change. It happens on both wires and wireless devices.
Message 3 of 13
Guru
Ok, if it happens directly connected to the modem, then ISP needs to review what I posted about.
Message 4 of 13
Rydaquin
Firmware VersionV6.01.07
TimePriorityDescription
2024-11-05, 20:27:48Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:27:44Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:27:39Notice (6)CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:27:06Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:26:58Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:26:38Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:26:35Notice (6)CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:26:32Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:25:35Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:25:34Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:25:26Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:25:26Notice (6)CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:25:09Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:24:51Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:24:35Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:24:21Notice (6)CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:24:15Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:23:24Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:22:25Notice (6)CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:22:23Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:22:21Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:21:21Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:21:08Notice (6)CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:20:15Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:19:10Notice (6)CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:19:03Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:18:43Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:18:42Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:18:06Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:18:00Notice (6)CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:17:35Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:17:08Notice (6)CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:17:07Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:16:55Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:16:38Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:16:14Notice (6)CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:16:13Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:16:00Notice (6)CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:15:52Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
2024-11-05, 20:15:45Notice (6)CM-STATUS message sent. Event Type Code: 4; Chan ID: 25 26 27 28 33 34; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1;
For the Modems Cable Connections Status it says it's good. Did you want me to copy and paste those charts under Cable Connection?
Message 5 of 13
Rydaquin
Also I forgot to mention earlier. When I restart the modem and router, the speeds are fine for a minute but then they'll start to slow down.
Message 6 of 13
Guru
Yes, need the full data from the cable connections page please.
Message 7 of 13
Rydaquin
Apply             Cancel
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
<tabindex=-1>Startup Procedure</tabindex=-1>
ProcedureStatusComment
Acquire Downstream Channel807000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnableBPI+
IP Provisioning ModeHonor MDDIPv4 only
<tabindex=-1>Downstream Bonded Channels (Partial Service)</tabindex=-1>
ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1LockedQAM25613807000000 Hz-2.2 dBmV43.7 dB299806690150
2LockedQAM2565759000000 Hz-2.2 dBmV38.8 dB299726979445610
3LockedQAM25617831000000 Hz-2.5 dBmV43.7 dB299727790950
4LockedQAM25618837000000 Hz-3.3 dBmV43.2 dB299728247210259
5LockedQAM25619843000000 Hz-3.0 dBmV43.3 dB299729313340
6LockedQAM25620849000000 Hz-2.7 dBmV42.5 dB299729671590
7LockedQAM25621855000000 Hz-2.2 dBmV43.0 dB299730021290
8LockedQAM25622861000000 Hz-2.7 dBmV43.3 dB299730349470
9LockedQAM25623867000000 Hz-3.7 dBmV42.9 dB2997307598120
10LockedQAM25624873000000 Hz-3.4 dBmV41.1 dB299731073050
11LockedQAM25625117000000 Hz-2.6 dBmV35.8 dB2614510233112353068132308
12LockedQAM25626123000000 Hz-0.8 dBmV38.2 dB29968524174611753830
13LockedQAM25627129000000 Hz-2.4 dBmV36.9 dB208339800331813715789
14LockedQAM25628135000000 Hz-2.4 dBmV40.3 dB120872490878167543
15LockedQAM25630147000000 Hz-2.9 dBmV38.5 dB2997275732507982343
16LockedQAM25631153000000 Hz-2.3 dBmV41.4 dB268153000314568222069914
17LockedQAM25632159000000 Hz-1.6 dBmV42.6 dB299731740017666957
18LockedQAM25633165000000 Hz-2.9 dBmV35.9 dB29971118412245962991
19LockedQAM25634171000000 Hz-1.7 dBmV41.9 dB2862125081143510639
20Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
21LockedQAM25636183000000 Hz-1.9 dBmV42.9 dB2997256860872422342
22Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
23LockedQAM25638195000000 Hz-3.2 dBmV42.4 dB2997325652237231746
24Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
25LockedQAM25640207000000 Hz-1.9 dBmV27.0 dB980369586537877504103330156
26Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
27LockedQAM25642219000000 Hz-0.5 dBmV44.1 dB29973535491784516
28LockedQAM25643225000000 Hz-1.9 dBmV42.8 dB299735202344861564
29LockedQAM25644231000000 Hz-2.8 dBmV42.7 dB29973603052788689
30LockedQAM25646243000000 Hz-2.9 dBmV42.8 dB29973609033172273
31LockedQAM25647249000000 Hz-2.1 dBmV42.6 dB29973555412969651
32LockedQAM25648255000000 Hz-0.8 dBmV43.2 dB29973585561796307
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
1LockedATDMA116900000 Hz43.3 dBmV
2LockedATDMA223500000 Hz45.0 dBmV
3LockedATDMA329900000 Hz44.5 dBmV
4LockedATDMA436300000 Hz43.8 dBmV
5Not LockedUnknown00 Hz0.0 dBmV
7Not LockedUnknown00 Hz0.0 dBmV
8Not LockedUnknown00 Hz0.0 dBmV
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1Locked0, 1, 2, 3159300000000 Hz-0.8 dBmV36.5 dB296 ~ 789512383236359230034340941554
2Locked0, 1, 2, 3160918000000 Hz-3.4 dBmV38.3 dB2216 ~ 59756155632788146966501526
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
1Locked3, 4, 9, 10, 11, 12, 13636800000 Hz38.5 dBmV
2Not Locked3, 4, 9, 10, 11, 12, 1300 Hz0.0 dBmV
Current System Time: Wed Nov 06 16:47:02 2024System Up Time: 18:19:52
Message 8 of 13
Guru
Ok. You have tons of Correctables and Un-correctables that should be mostly zeros across all channels.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
Message 9 of 13
Rydaquin
Message 10 of 13
Guru
Let us know how it goes. Hopefully good to go now.
Message 11 of 13
Rydaquin
Thank you for the help. Looks like it's all good now, haven't had any drops in speed.
Message 12 of 13
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 1192 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
