Orbi WiFi 7 RBE973
Reply
CM1150V - NETGEAR01 SSID
billnh
Follower
I installed the CM1150V Cable modem about a month ago.  I noticed that there is another network with an SSID of NETGEAR01.  It's the same strength as my Router's SSID.  When I try to connect to it, it doesn't take the default password or the one I changed the admin of the CM1150V modem.  Any idea of what the password could be or how I disable this network?
Message 1 of 2
Guru
Re: CM1150V - NETGEAR01 SSID
Whats your router?
the CM1150V is a modem with voice. It doesn't have wireless built in.
so whatever you're running for a router is likely to be that. Maybe its a dual band? Or did you put the wrong modem model?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1236 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
