Orbi WiFi 7 RBE973
Reply
CM2000???
CM2000???
I was recently looking at the spectrum and cox approved list, and there is a Netgear CM2000 listed with a 2.5GBps ethernet port on it.  I am wondering where I can obtain the CM2000 or if it is a future product, or what the deal is...
Thanks
Message 1 of 55
Guru
Re: CM2000???
It hasn't been released/anounced yet.
And netgear doesn't release dates because so much depends on the ISP certification which is taking forever.
Message 2 of 55
Re: CM2000???
Weird that both Cox and spectrum have it on the approved list for their gig tier. Wonder why it hasn’t been announced if it’s been approved by the isp 🤷‍♂️
Message 3 of 55
Guru
Re: CM2000???
They usually wait on the elephant in the room to certify (xfinity).
Message 4 of 55
Re: CM2000???
Just checked it’s on their approved list as well. Wonder what the issue is...
Message 5 of 55
Re: CM2000???
https://www.cox.com/content/dam/cox/residential/support/internet/print_media/CM2000_DataSheet.pdf
Even shows on the new data sheet that everything is approved 🤷‍♂️
Message 6 of 55
Guru
Re: CM2000???
Might just be finishing testing. they need to be certified and then tested to ensure they work with them for the auto-activation.
Message 7 of 55
Re: CM2000???
Well bugger....
Message 8 of 55
Guru
Re: CM2000???
Good things comes to those who wait. Smiley Wink
Message 9 of 55
vkdelta
NETGEAR Employee Retired
Re: CM2000???
product is certified by 3 biggies. It is going to our validation process.
I would suggest to wait for some time ..
Message 10 of 55
Re: CM2000???
Need a beta tester 🤪
Message 11 of 55
Guru
Re: CM2000???
I have a feeling its already going through testing if the ISP's have certified it 🙂
Message 12 of 55
Guru
Re: CM2000???
Smiley Very Happy
Message 13 of 55
vkdelta
Re: CM2000???
already in test...
Message 14 of 55
aptninja
Guide
Re: CM2000???
Let's go Netgear!!!  Communicate to your customers when the CM2000 cable modem will be released!!!!
XFinity already has it on their compatibility list for Gigabit speed supported cable modems.
https://www.xfinity.com/support/devices/#auth
Message 15 of 55
Re: CM2000???
They all three have it on the list that’s what the original issue was. Is it going to be a Broadcom or puma chip?
Message 16 of 55
Guru
Re: CM2000???
Patience. NG doesn't post anythign until they accounce it.
Message 17 of 55
Re: CM2000???
Ironically you tell a bunch of people who started on 2400baud modems who now have gig connections at home we need “patience”
Message 18 of 55
Guru
Re: CM2000???
You don't need a CM2000 modem for 1Gig connections. There are other model modems that handle 1Gig connections.
Message 19 of 55
Re: CM2000???
No appreciation for a good joke 🥺🥺🥺
Message 20 of 55
Guru
Re: CM2000???
I know I know. I started out on a 14.4 dialup modem. I think I still have it somewhere. Ah the good ole days. Smiley Very Happy
Message 21 of 55
Re: CM2000???
PAC Bell 486 running windows 3.1 with a tv card. Was the prime computer of the time! Needless to say I’m trying to reduce lag as much as possible, and would love if this had a octacore processor to handle the processing of high amounts of traffic. 😂
Message 22 of 55
Guru
Re: CM2000???
I had a 286, mono card and two 20Mb HDDs.
The CM1100 is a good modem. I love the dual WAN ports. It allows me to have two routers connected. The CAX80 does as well. Smiley Very Happy
Message 23 of 55
Re: CM2000???
I have a cm1200 but spectrum doesn’t enable the other ports
Message 24 of 55
Guru
Re: CM2000???
I wondered if the CM1200 on another ISP would allow the other ports to be enabled. I have a 1200 as well but didn't get a chanced to try the other ports. I know the CM1100 and CAX80 work on Sparklight.
Message 25 of 55
Top Contributors
Discussion stats
  • 54 replies
  • 8615 views
  • 12 kudos
  • 10 in conversation
Announcements
Orbi 770 Series
