Orbi WiFi 7 RBE973
Reply
CM400 firmware problem
russ0304
The firmware on my CM400 was upgraded by Comcast from v1.01.17 to v1.01.18. Now the event log will not open using Firefox v54 or IE11. In Firfox it just shows the spinning wheel, in IE11 error "Can't reach this page".
Model: CM400|DOCSIS 3.0 Cable Modem
Message 1 of 6
DarrenM
Sr. NETGEAR Moderator
Re: CM400 firmware problem
Hello russ0304
Have you tried chrome?
DarrenM
Message 2 of 6
russ0304
No, and don't intend to. I use Firefox and just tried IE because I have it.
Message 3 of 6
DrHitch
I replaced my Arris modem (Time-Warner furnished) with a NetGear CM400. I called them to change the MAC address. At first, it worked fine (both hardwired to PC as well as to my NetGear WiFi router.
But after 2 hours, the modem lights droped down to "no internet" and flashing "uplink".....The support people at T/W did a bunch of stuff inside my PC (DNS, IPconfig, etc) to no avail.
1) How do Ifind the firmware version of this modem?
2) Why does T/W have such a hard time getting this MAC address change to work?
3) I reverted back to their Arris modem and it seems to be fine again, but I want to usse my purchased CM400
Message 4 of 6
DarrenM
Hello DrHitch
You may want to call back and ask for there tier 3 internet support sounds like they did not code you account correctly for the new modem and the old one is still on the account.
DarrenM
Message 5 of 6
russ0304
Today Comcast upgraded the firmware on my CM400 from V1.01.18 to V1.01.19. The event log is now viewable.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3445 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
