paperboy201's avatar
Sep 24, 2016
CM500 Slow Download Speeds and Download light blinking green
Firmware Version V1.01.05
For the last few days, download speeds have been painfully slow and only the download light is steadily blinking green. All other lights are solid as they should be.
I have done factory resets and all troubleshooting possible including everything that was recommended by the ISP. I use Comcast Xfinity and pay for 75 mbps.
Current tests show .18Mbps Download and ~7Mbps Upload through hardline connection to Modem. ISP has looked at everything else and can only point to the router. Has anyone else had the
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello paperboy201
    Have you bypassed your router and connected direct to the modem and done a speed test?
    DarrenM
  • Yes I have. The .18 Mbps speed test was conducted via hardline directly to modem.
    Light has now been continuously blinking green for 5 days.
      • paperboy201's avatar
        paperboy201
        Tutor
        Go figure that the light stopped blinking late last night and I was not even afforded the chance to work towards a warranty claim. I'm waiting for the modem to act up again if it should do so.  Since I don't know what exactly happened and I'm not convinced that it won't happen again, should I still submit a claim?
        I do not know now what the issue was and I may not ever know. If the modem has issues again I will come back to this thread as the solution is still unknown. If anyone else has had similar issues with a similar modem then your insight and experience would be much appreciated.
        Thank you for your help Darren.
  • Recently I have similar problem with cm500. I have to reboot the modem every day to restore the 100mbp download speed. Otherwise it's around 12mbps.
    Also, the downstream blinks occationally
