- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cable Modem Wifi Router with SNMP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which cable modem Wifi Routers supports SNMP ?
Based on a previous post the SNMP is only available to ISP on the AC1900 C700.
I don't understand why the router supports SNMP but it is then blocked !!
Is there a different model which has full SNMP support ?
Also - do you have a table view which compares all of the cable model features between all of your product offerings. You have too many choices, hard to pick one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cable Modem Wifi Router with SNMP
SNMP tends to be more business class products and not consumer products.
Not sure if you'll find anything from netgear on the consumer side supporting it for modem/router.
Why not just get a modem only device and setup your own router that supports snmp.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I use the SNMP to monitor the load on the router via my smart phone.
My cheap TP-Link Archer C50 V5 supports it.
Seems like a simple enough feature to allow for easy remote monitoring.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
