- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can anyone help me with my new CM 2000 nighthawk modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello I just bought a CM 2000 Nighthawk Modem only not a combo. And When I got everything set up It was running perfect for my Speeds I pay for 500 down and 20 up and i was getting to about 485 down and 23 up. So After a little while it was cutting in and out of playing Warzone. And i've tried a lot of troubleshooting changing cables I have cat 6 cables, trying different ports. But When i went to check the event log this all came up if anyone can understand what any of this means please help me.
Thank you for your time and help much appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can anyone help me with my new CM 2000 nighthawk modem
photos have to be approved by a moderator. and it can take a while.
Or you can click on "choose file" when your reply and add them one at a time.
I'd also make sure to include the cable connections page with the logs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
okay I just got off the phone with netgear and the agent said that my downstream channels are good but my upstream channels are using a lot more power than they should. She told me that the power levels should be around 35 dBmV to 40 dBmV. Here are mine for my upstream.
She said it was either my coax line or something my isp can push through to see if it fixes it. So I called my ISP and I have a tech coming out tomorrow to check the coax line.
Power | ||||||
1 | Locked | ATDMA | 1 | 5120 | 17600000 Hz | 51.3 dBmV |
2 | Locked | ATDMA | 2 | 2560 | 25600000 Hz | 52.8 dBmV |
3 | Locked | ATDMA | 3 | 5120 | 30400000 Hz | 57.5 dBmV |
4 | Locked | ATDMA | 4 | 5120 | 36800000 Hz | 53.3 dBmV |
- Mark as New
- Bookmark
- Subscribe
- Permalink
The 57 is high. the rest are technically within spec. Its tough to know without all the data because if you're downstream power levels are low, it means that you're futher from the hub. That causes the upstream to need to be higher to send a signal back to the hub.
the only time i see people with their upstream at 35 is if they're right next to the hub.
do you have a full screen snip of both the upstream/downstream and the correctables/uncorrectables?
As well as your logs?
that's a better way to check. you can add them one at a time to be viewed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream Bonded Channels (Partial Service) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream OFDM Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream OFDMA Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Mark as New
- Bookmark
- Subscribe
- Permalink
Time | Priority | Description |
Mon Jun 07 16:50:38 2021 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 1; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:50:36 2021 | (Warning (5)) | MDD message timeout;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:50:32 2021 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 21; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:50:19 2021 | (Warning (5)) | Dynamic Range Window violation |
Mon Jun 07 16:50:19 2021 | (Warning (5)) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:50:19 2021 | (Warning (5)) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:50:15 2021 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:50:10 2021 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:50:10 2021 | (Error (4)) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:50:10 2021 | (Error (4)) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:50:10 2021 | (Warning (5)) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | (Notice (6)) | Honoring MDD; IP provisioning mode = IPv4 |
Time Not Established | (Critical (3)) | No Ranging Response received - T3 time-out;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:48:40 2021 | (Critical (3)) | Resetting the cable modem due to docsDevResetNow |
Mon Jun 07 16:21:58 2021 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 1; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:21:48 2021 | (Warning (5)) | MDD message timeout;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:21:45 2021 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 21; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:21:30 2021 | (Warning (5)) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:21:26 2021 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:21:26 2021 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:21:26 2021 | (Error (4)) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:21:26 2021 | (Error (4)) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:21:26 2021 | (Warning (5)) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:21:22 2021 | (Notice (6)) | Honoring MDD; IP provisioning mode = IPv4 |
Mon Jun 07 16:21:16 2021 | (Critical (3)) | No Ranging Response received - T3 time-out;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:21:02 2021 | (Critical (3)) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:20:14 2021 | (Warning (5)) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:20:13 2021 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:20:11 2021 | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:20:05 2021 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:20:05 2021 | (Error (4)) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:20:05 2021 | (Error (4)) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 07 16:20:05 2021 | (Warning (5)) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have any splitters or signal attenuators in line? Your upstream levels are higher than they should be basesd off your downstream.
Plus you have power violations in the logs and signal issues int he logs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
after changing something in the line, rechecking the cable connection info and logs is needed.
It shows how the signal has changed. Plus the cable connections page is just a snip in time, the logs show us the longer term signal.
also, check the website you're testing on. I've had some test servers have issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Downstream Bonded Channels (Partial Service) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream OFDM Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tue Jun 08 07:20:29 2021 | (Warning (5)) | Dynamic Range Window violation |
Tue Jun 08 07:20:29 2021 | (Warning (5)) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1; |
Tue Jun 08 05:15:21 2021 | (Warning (5)) | Dynamic Range Window violation |
Tue Jun 08 05:15:21 2021 | (Warning (5)) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=38:94:ed:0a:dc:60;CMTS-MAC=00:bc:60:93:42:ae;CM-QOS=1.1;CM-VER=3.1;
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
your having power levels that are going out of spec.
the cable connections page shows what they're actively at
- Mark as New
- Bookmark
- Subscribe
- Permalink
