Orbi WiFi 7 RBE973
Reply
Can't log in to Nighthawk - AC1750 Model C6300v2
jschwags
Follower
I need help! I can't get it to accept password as the password and I've done a factory reset. Any suggestions would be appreciated.
Thanks!
Message 1 of 2
Guru
Re: Can't log in to Nighthawk - AC1750 Model C6300v2
Wire connect a PC to the modem and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to 192.168.0.1 or 192.168.1.1 using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 312 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
