Orbi WiFi 7 RBE973
Reply
Cannot connect to internet. CM600
Godspeed3wsa
In trying to connect new CM600 I got 2 yellow "lightning bolt" lights.  Should all 5  be green instead?  Spent 45 minutes w. ISP technician ( Windstream) who registered my new modem but never got any connection.  Tech said all lights should be green.
Model: CM600|CM600 High Speed Cable Modem
Message 1 of 7
Accepted Solutions
Joi007
Tutor
Re: Cannot connect to internet. CM600
Gald you are all set. The CM600 is a solid modem.   Thanks for letting us know.
Message 6 of 7
All Replies
Guru
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
Message 2 of 7
Joi007
Tutor
Sounds like a provisioning issue. Have them verify the MAC address you gave them for the new CM is correct.
Might want to have them reprovision the line since this may be a provisioning issue.
The amber lights you see are one d/l channel locked for both up and down stream. See chart.
Message 3 of 7
Guru
Any progress on this?
Message 4 of 7
Godspeed3wsa
All fixed now.
I had a tech from ISP visit and he got us online quickly. Don’t know what he did but it’s all working.
Thanks for your concern.
Message 5 of 7
Joi007
Tutor
Message 6 of 7
Guru
Please mark your thread as solved so others will know.
Enjoy. Smiley Wink
All fixed now.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 4016 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
