- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connection issues with c6250
- Mark as New
- Bookmark
- Subscribe
- Permalink
My router is having intermittent connection issues. Periodically it'll just cut out and I won't have a connection for 5 minutes or so before it comes back. On the bottom, it's labeled as a Netgear AC1600 Wi-Fi Cable Modem Router, model C6250. I've had it since late 2018 and it's worked fun up until several months ago when the issues started appearing. I've posted a copy of the event log from the last couple days. I don't understand any of it, so any help with it would be appreciated.
2024-6-12, 09:15:54 | Warning (5) | Dynamic Range Window violation |
2024-6-12, 09:15:36 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 08:59:59 | Warning (5) | Dynamic Range Window violation |
2024-6-12, 08:59:58 | Notice (6) | WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
2024-6-12, 08:59:58 | Warning (5) | Dynamic Range Window violation |
2024-6-12, 08:59:57 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 08:59:55 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 08:59:55 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 08:59:55 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 08:59:55 | Error (4) | Missing BP Configuration Setting TLV Type: 17.7;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 08:59:55 | Error (4) | Missing BP Configuration Setting TLV Type: 17.6;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 08:59:55 | Error (4) | Missing BP Configuration Setting TLV Type: 17.5;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 08:59:55 | Error (4) | Missing BP Configuration Setting TLV Type: 17.4;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 08:59:55 | Error (4) | Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 08:59:55 | Error (4) | Missing BP Configuration Setting TLV Type: 17.2;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 08:59:55 | Error (4) | Missing BP Configuration Setting TLV Type: 17.1;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
1970-1-1, 00:00:39 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.0;CM-VER=3.0; |
1970-1-1, 00:00:36 | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
1970-1-1, 00:00:31 | Notice (6) | WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT |
1970-1-1, 00:00:31 | Notice (6) | WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT |
1970-1-1, 00:00:29 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
2024-6-12, 06:36:31 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 06:35:41 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 06:35:41 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 06:34:10 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 05:17:55 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-12, 03:57:58 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-11, 22:12:42 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
2024-6-11, 22:12:39 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-11, 22:04:24 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-11, 07:41:14 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-11, 07:32:35 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-11, 07:16:37 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-11, 07:16:37 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-11, 07:14:41 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-11, 07:10:21 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-11, 06:58:23 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-11, 06:45:44 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-11, 06:27:19 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
2024-6-11, 06:26:55 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=3c:37:86:03:5b:90;CMTS-MAC=00:01:5c:87:44:71;CM-QOS=1.1;CM-VER=3.0; |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connection issues with c6250
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is what I'm seeing:
Procedure | Status | Comment |
Acquire Downstream Channel | 597000000 Hz | Locked |
Connectivity State | OK | Operational |
Boot State | OK | Operational |
Security | Enabled | BPI+ |
IP Provisioning Mode | Honor MDD | honorMdd(4) |
Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream Bonded Channels (Partial Service) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok power levels are good.
However you have correctables and un-correctables that should be mostly zeros.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you! I'll give all that a try. Will report back here if there continues to be any issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your logs are indicating a line issues.
The problem with the C6250 is that is only a 16x4 modem.
meaning it doesn't cover all the channels and modems like to switch between channels.
So it might look fine now, but not all of them might be.
From there check the line for kinks, damage, and moisture in the line.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISPs charge if the wiring issue is in the home. So this helps prevent this.
If that doesn't help, the ISP needs to check the line.
You might also check into upgrading at some point. The C6250 is getting older/slower/depreciated. Its coming up on time to upgrade to docsis 3.1 and a different router (prefer modem separate from the router in my experience).
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
