Orbi WiFi 7 RBE973
Reply
Connection issues
TeresaBarnes-62
Follower
Connection issues
Model: C3700|N600 Cable Gateway Docsis 3.0
Message 1 of 2
Guru
Re: Connection issues
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 362 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
