Orbi WiFi 7 RBE973
Reply
Double nat on xbox
Twilken98
Double nat on xbox
Keep getting double nat on my xbox, I switched to just a single modem/router instead of having both and it still keeps giving me a double nat. I've run out of ideas.
Model: C6220|DOCSIS 3.0 High Speed WiFi Cable Modem Router
Message 1 of 11
Guru
Re: Double nat on xbox
Did you hard power OFF the xbox by pressing the front power button and holding it until the xbox shut off? Then reboot the modem router and then turn on the xbox?
Message 2 of 11
Twilken98
Yes, even fully unplugged both for a min and let the modem/router to fully boot up before plugging in and turning on xbox...I've even tried port-forwarding.
Message 3 of 11
Guru
What happens if you hard power OFF the xbox then elave it off.
Factory rest the modem and setup from scratch. Use uPnP only with no port forwarding configurations. After the modem is setup. Power ON the xbox and check netwworking NAT status.
Is this the only xbox game console you have online or is the more then one?
Message 4 of 11
Twilken98
That's actually how I did it straight from the get go hoping the new modem router would resolve the issue but it did not and yes it is the only gaming consol connected and only one of like 2 or 3 devices.
Message 5 of 11
antinode
Guru
> Keep getting double nat on my xbox, [...]
   Thanks for the analysis, but it might be helpful to see how you
arrived at that conclusion.  Actual error message from something?
> [...] I switched to just a single modem/router instead of having both
   What did you have before?
   That's what you have now?
   What's the IP address of the WAN/Internet interface of the C6220?
(ADVANCED > ADVANCED Home : Internet Port : Internet IP Address)
   What's the (LAN) IP address of the Xbox?
Message 6 of 11
Twilken98
Before I had a netgear modem and a lynksys router. I have a set IP for the xbox set to the modem/router and the IP is set to whatever off of the ISP.
Message 7 of 11
antinode
Guru
> Before I had a netgear modem and a lynksys router. [...]
   Not a very detailed description of anything.
> [...] have a set IP for the xbox set to the modem/router [...]
   Not what I asked.  What I asked was:
> [...] the IP is set to whatever off of the ISP.
   If you're worried about revealing secrets, then the top half, "a.b"
out of "a.b.c.d", would satisfy my curiosity.  Is that address a
private/non-routable address?  (If it's not obvious, then plug it into
the form at: https://whois.arin.net/ .)
   Possibly relevant (but, with no useful information, it's hard to
guess):
      https://en.wikipedia.org/wiki/Carrier-grade_NAT
   You might waste less of everyone's time if you answered the questions
which were actually asked, rather than the questions which you
apparently wish had been asked.  For example:
> [...] it might be helpful to see how you
   Just a thought.
Message 8 of 11
pccr
Did you ever get this solved? I have a TP-link modem and a Netgear R6120 AC1200 router now. I can't seem to solve my kid's Xbox "double NAT" so I was going to buy a modem/router combo to solve the issue  CUZ how could one box give you a double NAT??? But you scare me with the C6220 giving you trouble ... If I had C6220 going straight to my cable coming in the house, I can still get a double NAT on my WiFI router side? Geez. Why even buy a combo box then? This was going to be my solution.
- P
Message 9 of 11
antinode
Guru
> [...] I have a TP-link modem [...]
   Has this "modem" a model number?  (Is it a "modem" or a
modem+router?)
   By itself, that difference would justify opening your own new thread
for your own problem, rather than joining this old, dead-end thread.
> [...] If I had C6220 going straight to my cable coming in the house, I
> can still get a double NAT on my WiFI router side? [...]
   You can, if your (unspecified) ISP uses carrier-grade NAT.  Did you
read any of the previous stuff here?  Clearly, you didn't grasp the
value of a useful description of your "a TP-link modem".  Did you
consider answering the other questions which the OP failed to answer
about his environment?
> [...] Why even buy a combo box then? [...]
   It's more compact, with one less pesky Ethernet cable?  If you ever
need a new/better modem, it encourages you buy a new router, too?
> [...] This was going to be my solution.
   Perhaps it would be helpful to determine the cause of the problem
before deciding on a solution to it.
Message 10 of 11
pccr
I didn't see this response before the parallel thread response. While I am sure you get tired of talking to a lot of newbies trying to figure out their internet problems, berating them does not help. Most of the people you are talking to do not know what they are not telling you.
I will say that this part of your response was very helpful. "You can, if your (unspecified) ISP uses carrier-grade NAT." I looked that up and it seemed to help explain why a "tracert 8.8.8.8" would show an extra private IP address I could not explain. I called my ISP and they changed the setting to open on my privately own TC-7610 and my daughter's XBOX now reports an open NAT type. Amazingly, the tracert still shows the extra private IP address (but a different one) so I still don't understand all this.
So you did help me fix the issue and saved me $100+. Thanks!
- P
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3630 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
