- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Fast LAN speed/slow WiFi speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Fast LAN speed/slow WiFi speeds
Everything was slow. So, I've rebooted the dell laptop, android phone, and iPad, and now they all are getting a faster download speed, 26, 14, and 36 Mbps, respectively
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does that mean it's all working now?
- Mark as New
- Bookmark
- Subscribe
- Permalink
After playing around with the settings a few times and adjusting the location of the router. I am not getting far hight download speeds than before. On IPv6. I am gettng speeds of up to 60 Mbps over wireless. Which is more than half the speed I was told I could expect using LAN. And between 27 and 34 on IPv4. So it's pretty fast now.
Appreciate the help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
what do you mean on IPv6 and IPv4?
Also what did you do to get the wifi speeds up
mine is still bad on 2.4G (like 5 Mbs max) and 5 G (26 Mbs max) out of 105 Mbs hardline speed.
I called F*#king net gear on the phone and they wanted me to pay $120 to buy what the call over the phone support, what a clowns, never heard of a company that wants to charge you many for supproting their crappy products.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Isaac85 What's the exact model number and version of your device?
Do you have the latest firmware installed on your unit?
IPv6 and IPv4 is the type of connection that's being used.
Hardwired connection is totally different from wireless connection.
What's the wireless adapter being used?
How do you measure your speed? Is this done through a laptop or a mobile device?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did factory reset on my WNDR 3700. Getting 29 Mps wired and 11 WiFi using EX600 range extender. Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@modave Do you have the latest firmware installed?
Without the extender what's the speed of your wireless?
Which signal you're connecting to (2.4GHz or 5GHz)?
What's the speed when you directly connect your computer to the modem?
How many wireless devices are connecting wirelessly?
What are these wireless devices?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes
Without extender -12.13 down and 5.96 up
2.4, 5.0 not coming up after reset
I can't connect to net plugged directly into modem. Modem is 1 day old. Netgear CM500. Speed when direct wired into router is 26.03 down and 6.07 up.
8 Devices, 1 desktop, 1 laptop, 2 iPads, 1 ooma phone system and 1 cell phone
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had 5.0 G before reset. How do I get it back?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What's the speed you're paying for?
Why can't you bypass the router?
It's best to bypass the router to verify the speed promised by the ISP.
When you say that the 2.4GHz and 5GHz doesn't come up after reset, does that mean that the wireless light on the front of the router is turned off?
What's the exact model number of your unit?
Do you have any wireless button on the front panel of the router to turn on/off the wireless feature?
- Mark as New
- Bookmark
- Subscribe
- Permalink
25Mps
When Ethernet connected directly to hte modem, I cannot connect to net.
5G light is solid blue and 2.4 is flashing green
I connected to 5G network on iPad and did speed test and got 29.03Mps and 6.09 up
Installing USB wireless adapter to see if it helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@pdrupareliya What's the model number of your NETGEAR device?
2.4GHz is really prone to interference and that might be the reason why you're getting that speed.
Wired can't be the same as the wireless speed. These 2 are totally different connections and there are factors that needs to be considered when it comes to wireless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mohan5k What's the exact model number of your device?
What's the firmware version installed?
All devices are affected?
What are the devices affected?
Kindly describe further on what you're experiencing so we can provide better response.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wired connection directly to modem: 180 mbs (comcast)
Wired connection through router: 20 mbs
Wireless connection using router: 20 mbs
Same issue with all devices
Not a cable issue for the wired connection (tried several)
no interferences from other devices (and of course, this wouldn't explain the wired slow connection)
on latest firmware
did the 30-30-30 that briefly improved the WIRED connection only, but minutes later it reverted to 20 mbs
The router clearly seems to be a bottleneck, and it is not just a wifi issue. Any solutions short of getting a new router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This should have been corrected by a firmware upgrade and reset.
Since you're still experiencing the same thing, I suggest that you get a new router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm consistently getting slower speeds through my wireless connection vice hardware. Hardwire directly into my modem I have 25Mbs download, yet wired I only get ~12Mbs. I've check and the router is stating it has the latest firmware (V1.0.1.14). Any suggestions?
I had this problem a while back and it just seemed to resolve itself, but it seems to be back. Of note, the wifi speed was down to less than 5MBs, but after a restart it jumped up to the now 12MBs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you can make sure that it's not an Ethernet cable problem then it's time to get a new router.
This matter should have been corrected by the firmware and reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anything we can do short of purchasing a new router? My router began having these dreadful wifi speeds about 3 1/2 months into owning my netgear product. If these things really crap out that soon, that'd be a shame. I've done virtually everything recommended in this thread and am still experiencing speeds < half of my LAN speed. My LAN speed is fantastic and strong, but as soon as I hard wire or connect to my router wirelessly those speeds diminish. In fact, I get almost NO upload which is difficult because I produce music and tend to share it with people which is impossible with 0.1kbps upload speeds. I've resorted to transferring my songs onto my phone and uploading them via my phone's 4G network. I feel like I'm wasting money paying for internet that I don't get to enjoy because of a cheap product. I'm pretty financially strained and going out of my way to purchase a nicer router isn't realistic. I'm on the latest firmware version, have found unused wifi channels to set my wireless connections to, hard-reset my router, tried different cables and more. If this is how netgear products operate, I don't think I'll wanna buy them in the future.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- Next »
