Vpbomp's avatar
Vpbomp
Firmware file c7000
Hello !!I am looking for a firmware file for this device, mine bricked itself ;( during an update lost power
  • plemans's avatar
    That's not good.
    there isn't a firmeware file because it comes from the isp.
    You can attempt to have the isp re-provision it or reinstall firmware but its not something the user can do.
    • Vpbomp's avatar
      Vpbomp
      I'm able to communicate with the unit
      Same ip schem, subnet.
      I believe I can send the file over tftp
      Just need the file
      • plemans's avatar
        Again, you can't get the file. Only the isp has it. its the way combo devices work and one of the reason's we usually recommend people buy modems seperate from routers.
        Have you tried a factory reset?
        Or a 30/30/30 reset?
