johnluan's avatar
johnluan
How can I open port 80
My modem is CM500V-1staus.
I can port forward to any other port, but not port 80.
I called optus, they said they only block port 25.
Does anyone know how to open port 80?
It works at my laptop(inside the network) with the public ip, but not external servers, for example,from office call to my public ip, port 80 is blocked.
Cheers,
John
    • johnluan's avatar
      johnluan
      TPLink, I don't think this is the router problem, before I switch to optus,(or  switching to this modem). I have no issue at all for port 80.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    CM500V-1STAUS is a bridged modem. It has capability to block the ports unless Optus themselves blocks using docsis L2 or L3 filters or firewalls.
    • vkdelta's avatar
      vkdelta
      I meant "It has NO capability" ..
      you might to check with Optus as this is specific product customized for Optus according to their requirements.
      also, test with device directly connected behind CM.
      • johnluan's avatar
        johnluan
        Thank you for your reply, I asked optus, they said they only block port 25, they ask me to ask Netgear...
  • Exact same problem and model.
    Network was floorless before this. I added this modem into the system (downgrade form NBN as i moved), and now it no longer allows me to connect to my server via 80.
    Really need to be able to do this.
    Cheers
