- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to use the r6100 as a router connected to a C3700 modem/router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello - I have a Xfinity 150 meg per second internet package. I bought a C3700 modem router combo and used it for a few months. Being that we have over 20 devices connected to it, I wanted a simultaneous dual band router and bought the r6100. The current configuration is this - The cable coaxil goes into the modem or c3700. A CAT6 ethernet cable goes from the c3700 to the r6100 internet port.
No other configuration is done within either devices firmware. All settings are stock with an exception of the SSID and password and the Netgenie password was changed also.
Both SSID's are named identical to support dual band simultaneously. Everything works, but I'm wondering if this is the most secure way to use these two netgear devices. I'm testing in the low 90's as far as megs per second. We pay for 150 which makes me think something isn't setup optimally. Any suggestions would be greatly appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello japublications
Did you set your R6100 up as a access point if so that may be why it does not work when you make the c3700 a modem only.
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to use the r6100 as a router connected to a C3700 modem/router
You will want to make one change to this setup. You will want to log into the C3700 go to advanced then Administration then router mode and select No this will make it a modem only so your R6100 will do all the routing right now you may have problems because you have 2 routers connected to each other that could cause conflicts.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
DarrenM
User | Count |
12 | |
4 | |
3 | |
2 | |
2 |
