Orbi WiFi 7 RBE973
Reply
Identifying the difference between Nighthawk CM1000 vs CM1000v2
NEK356
Follower
Good Day.  I am interested in purchasing the Nighthawk CM1000 cable modem.  My ISP is Spectrum and have read that I should get the "v2".  How can I identify and confirm that the cable modem I am selecting is in fact v2?  I just want to make sure I am purchasing a product that will work with Specturm in Los Angeles, CA.
Thank you.
Model: CM1000|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready
Message 1 of 3
Accepted Solutions
Guru
Re: Identifying the difference between Nighthawk CM1000 vs CM1000v2
Something to ask NG support about. See if you can get some info.
@Christian_R
@vkdelta
You might look at the spec sheets for each and see if you can gleem some information. Possible just a minor HW change.
Message 2 of 3
All Replies
Guru
@Christian_R
@vkdelta
Message 2 of 3
antinode
Guru
> [...] How can I identify and confirm that the cable modem I am
> selecting is in fact v2? [...]
      https://community.netgear.com/t5/x/x/m-p/1920331
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5032 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
