- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Internet Problems
- Mark as New
- Bookmark
- Subscribe
- Permalink
Internet Problems
My ISP is Xfinity. I have 300 mbps.
My modem is in the back room but like I said, I had no disconnect issues before. Everything was excellent.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Internet Problems
1. do you have a screen snip of the cable connections page and event logs?
2. do all devices drop or just wireless or wired?
3. It only has issues when streaming your twitch stream? Reason I ask is you might pay for 300mbps but the upload is usually only like 5mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This pic is the event logs which are nearly all critical
- Mark as New
- Bookmark
- Subscribe
- Permalink
you're showing line issues.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, loose connections, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll try that coax trick
Everything else should be fine. I never had any issues for the two years I've had xfinity. Just when I got a new modem and wanted to try streaming xD
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
