- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is Quality of Service (QoS) customizable on CM600?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I'm intersted in buying a new modem (CM600) that will allow me to prioritize my VoIP devices (a Polycom handset provided by my employer and a Verizon femtocell/network extender.) I've noticed in my current setup that voice calls occasionally get disturbed when my family is streaming Netflix. They often have 2 concurrent Netflix streams running while I'm making calls. I've tried searching, and have only briefly seen mention of "Advanced QoS" on the high-end modem. However, I'm unclear if this QoS is adjustable to suit my needs. I just want to provide the IP addresses of my two devices, and tell the modem that anything from those two devices gets prioritized. I'd appreciate a screenshot of the configuration screen, if available. I searched the Users' Guide, but didn't find anything.
Thanks,
John
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello JohnCall
I have checked and there is no configuration on the CM600 for QoS settings and we will be checking with marketing to update the documents if require.
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is Quality of Service (QoS) customizable on CM600?
Hello Johncall
The CM600 is just a cable modem it does not have QOS settings on the device you would have to look at our Nighthawk routers for the Qos setting you can typically find screen shots for these settings in the user manual for the devices which you can find on our support page.
http://www.netgear.com/support/
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
http://www.netgear.com/home/products/networking/cable-modems-routers/CM600.aspx#tab-techspecs
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello JohnCall
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
