Orbi WiFi 7 RBE973
Reply
LEDs mean what?
dlwilladsen
Tutor
LEDs mean what?
Power blinking green, Up,Down,Internet ALL blinking amber, Lan1/2 both solid amber?
hdw v 1.0, firmware v1.3.2
Message 1 of 6
Accepted Solutions
Guru
Re: LEDs mean what?
Can try a 30-30-30 reset on the modem to see if anything changes. If it doesn't, modem may have gone bad.
Message 4 of 6
All Replies
Guru
Re: LEDs mean what?
What does the user manual say?
Power OFF the modem. Disconnect the ISP cable coax line and external router from the modem. Then power ON the modem See if only the power and downlink LEDs come on.
That ISP are you connected with?
Message 2 of 6
dlwilladsen
Tutor
Re: LEDs mean what?
Manuals don't show anything near this configuration.
I'm with Mediacom.  Switched to my backup modem (Motorola 7420) and all is well.
Disconnected ISP and router cables -> ends up same configuration of LEDs (pwr blinks green, down/up/internet blinks amber, Lan1/2 both solid amber.
Message 3 of 6
Guru
Re: LEDs mean what?
Message 4 of 6
dlwilladsen
Tutor
Re: LEDs mean what?
Must be bad then.? (tried 30-30-30 to no avail)
Thanks for the suggestions!
Message 5 of 6
Guru
Re: LEDs mean what?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 632 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
