AlistairPhoenix
Jun 29, 2017Aspirant
Modems rebooting after heavy use
After about 4 cable technicians and many nights of constant failures, I wanted to turn to the internet for answers.
In the past month, my modem is constantly rebooting itself after 4 or so hours of constant use. This is especially annoying since I play online games and having to be disconnected for brief moments.
My cable provider is Suddenlink and I have had them for 2 1/2 years. The only problems I had with them was when I needed their rental modem replaced. After 2 years, I decided to get my own modem to save on money. My first modem was an Arris Surfboard Cable Modem Model SB6141.
It was working just fine up until recently. I could surf the web and I could play my games without fear of having a random disconnect. So to have it start after a few months of use was worrying. So I decided to do a bit of troubleshooting. I first started with power cycling and factory reseting. Didn't work. I then tried getting a UPS and giving it its own power source. The modem still rebooted itself after a few hours of use. I tried to see if heating was an issue. My room is well ventilated and is constantly at low tepperature with a fan blowing through the room. I then replaced my modem with the CM400 Netgear modem to see if that would work.
Nope.
It did the same thing as the other modem. So, then I called the technicians out there. The first technician removed a filter on the line to see if that worked. He leaves, I start using the internet. 4 hours later, the modem reboots itself. I call a 2nd technician out here. This technician gives me my own line and even replaced the splitter I was attached to and puts it on a three way splitter.
For reference, the cable reaches from at least 3 poles and to a 2 way splitter before they attache another cable that is covered and buried underground. The coaxial cable is then brought through the floor of the trailer and attached to the modem.
4 hours later, modem reboots.
I then call a third tech to see if they would know anything else to replace. The guy just tests the connection and tells me that I either have a grounding issue or an electric issue. My trailer has a grounding box and everything in the trailer has been working fine, no fluctuations or anything. He also mentions that the SNR was fine and passable. So he just places another splitter on the line; this time inside the trailer before it hits the box.
I checked the logs for my modem and saw that the power levels as well as the noise was well within the recommended range and yet when I look at my logs I keep seeing T3 Timeouts every so often.
I called a fourth tech out today. It was the same guy as last time. All he does it check the connection on his equipment, tell me nothing is wrong, and leaves but not before saying something about seeing if I have a grounding issue or an electrical issue.
This is the only cable internet service I have in the area and nobody even knows what is going on with my modems.
When I say "reboot", I mean that all the lights, except for the power light, goes out and slowly blink back on.
Is there anyone here that has an idea as to what the problem really is?
- vkdeltaNETGEAR Employee Retired
Can you please post event log and power table for us to review?
- AlistairPhoenixAspirant
Event Log
Time Not Established Critical (3) DHCP failed - RS sent, no RA received
Time Not Established Error (4) Primary lease failed, IPv4 fallback initiated
Jul 4 17:07:10 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Time Not Established Critical (3) No Ranging Response received - T3 time-out
Jul 4 20:11:07 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 4 23:03:26 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 5 04:04:43 2017 Warning (5) Lost MDD Timeout
Jul 5 04:05:42 2017 Critical (3) No Ranging Response received - T3 time-out
Jul 5 04:06:36 2017 Warning (5) Lost MDD Timeout
Jul 5 10:09:15 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 5 14:09:47 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 5 17:56:59 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 5 22:54:27 2017 Warning (5) Lost MDD Timeout
Jul 5 23:18:55 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 6 04:18:12 2017 Warning (5) Lost MDD Timeout
Jul 6 04:29:11 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 6 09:24:55 2017 Warning (5) Lost MDD Timeout
Jul 6 09:43:52 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1- vkdeltaNETGEAR Employee Retired
can you please post your powet table as well from the connection page? thank you.
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables UnCorrectables
1 Locked QAM 256 1 567000000 Hz 8.7 dBmV 35.5 dB 24 686
2 Locked QAM 256 2 573000000 Hz 8.4 dBmV 35.5 dB 19 544
3 Locked QAM 256 3 579000000 Hz 8.2 dBmV 35.4 dB 6 541
4 Locked QAM 256 4 585000000 Hz 8.2 dBmV 35.4 dB 19 733
5 Locked QAM 256 5 591000000 Hz 8.5 dBmV 35.5 dB 29 615
6 Locked QAM 256 6 597000000 Hz 9.0 dBmV 35.5 dB 26 702
7 Locked QAM 256 7 603000000 Hz 9.3 dBmV 35.9 dB 31 651
8 Locked QAM 256 8 609000000 Hz 9.7 dBmV 36.1 dB 33 611Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power1 Locked ATDMA 44 2560 Ksym/sec 21400000 Hz 39.5 dBmV
2 Locked ATDMA 43 2560 Ksym/sec 25000000 Hz 39.8 dBmV
3 Locked ATDMA 42 5120 Ksym/sec 30700000 Hz 40.5 dBmV
4 Locked ATDMA 41 5120 Ksym/sec 37500000 Hz 41.3 dBmV
