- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear AC1750 serial number
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have lost the card that slips out of my router with the serial number and password on it. Is that information available anywhere else on the router. If it's inside I can take the cover off. I hate to have to buy another one when this one is working well. I had to reset my phone and lost the password for the router in the process. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear AC1750 serial number
> number and password on it. [...]
Which "password"?
> Model: C6300BD-1CXNAS|Docsis 3.0 AC1750 Cable Modem Router
Is that accurate? Cox is your ISP?
Assuming that "-1CXNAS" is right:
https://www.cox.com/residential/support/netgear-c6300bd.html
In the User Manual, look for "Types of Logins". According to that
manual, this device uses Netgear's standard "admin" and "password" as
the credentials for the management web site. If those don't work, then
a settings reset should restore them. Look for "Factory".
When you can access the management web site, you should be able to
see and/or change the wireless-network credentials (SSID, passphrase).
