- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear AC1900 mod.c7000v2 port forwarding
- Mark as New
- Bookmark
- Subscribe
- Permalink
I need to open some ports to allow a wifi device to commutate with manufacturer . I have downloaded the instruction fom netgear support . Not able ( or not sure ) whar ip`s they asking for . Keep getting errors when numbers are put in.
Here are the directions I have https://kb.netgear.com/000031585/How-do-I-add-a-custom-port-forwarding-service-on-my-NETGEAR-router?...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear AC1900 mod.c7000v2 port forwarding
what errors are you getting?
Its tough to help without info/photos/better descriptions of what you're putting in and attempting to do
- Mark as New
- Bookmark
- Subscribe
- Permalink
trying to add this device , A = these are the numbers i put in . get error IP address not in lan . invalid server .I guess I dont know what they are asking for .
- Mark as New
- Bookmark
- Subscribe
- Permalink
It might be easier if you provided a few more details about that.
Explain the problem you want to fix rather than what you have been told might be the solution .
What is this wifi device and why does it need messing around with ports?
That is not a typical requirement.
You never know, someone may have turned up here before with the same challenge.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're right. its not in your lan.
In your one photo, you're setting your port forwarding settings for 192.168.51.1
But the next photo is showing your router's lan range is in the .0 range (192.168.0.***)
- Mark as New
- Bookmark
- Subscribe
- Permalink
how do I fix this ? not my forte . thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
tough to tell you have to fix it because its usually a bit specific to your device.
You should be port forwarding to devices in the same subnet. So if you're router is on the 192.168.0.1 lan address, the devices should be 192.168.0.*** where the *** is the device specific ip address. You'd need to be using that address to forward to the device
- Mark as New
- Bookmark
- Subscribe
- Permalink
I Tried ,guess I don`t dont know which numbers to use ,Thanks for helping ,I give up .
- Mark as New
- Bookmark
- Subscribe
- Permalink
i got it this far . still not connecting to Mobile link ,Generac
- Mark as New
- Bookmark
- Subscribe
- Permalink
How does the supplier of this widget tell you to configure the port?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear has a link that I used to open the ports they ( Generac ) uses to communicate with the Generator. Generac helped open these , They are still closed according to port checker I used on line . Netgear wants to charge to help me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What generac device do you have (model)?
Their website instructions are a bit vague. Basically on their site, you connect your phone to the generac device's wifi and then go through the app setup to connect it to your router.
Where is it failing in the process?
- Mark as New
- Bookmark
- Subscribe
- Permalink
my replies disappear ?? I`v replied 3 times and its still not here ......
