Orbi WiFi 7 RBE973
Reply
Netgear C7800 Nighthawk X4s Ac3200
yager
Follower
Is the Netgear C7800 Nighthawk X4s Ac3200 WiFi Cable Modem Router compatible with a Fiber Internet service?
Message 1 of 2
Kitsap
Master
Re: Netgear C7800 Nighthawk X4s Ac3200
In a word, no.  The C7800 is a combination cable modem and router.  The only input is via a coax cable.
Your fiber service will have an Optical Network Terminal (ONT) for the termination point.  Normally the ONT has an Ethernet output and you would need a router.  Some ONTs are also combination devices that include a router.  Depending on what part of the world you are located, common practices vary.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1024 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
