- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Network Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the deal with the "said that the switch panel was defective on my unit" Is this regarding LAN ports on the CAX30 or the game console?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-mode...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
STATUS: GOOD
Security
STATUS : ENABLED
These are repeated many times in the event log, but I think I got the different log messages, I however don’t speak whatever language it’s in 😕
Event log, the brief time that the network has existed is alarmingly active… or a warning and critical that’s repeated many times, I think related to the dhcp issue
“ No Ranging Response received - T3 time-out;CM-“
“ Dynamic Range Window violation”
“ RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM” “ SYNC Timing Synchronization failure - Loss of Sync;CM”
“ DS profile assignment change”
“ Honoring MDD; IP provisioning mode = IPv6”
“ SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM”
“ Resetting the cable modem due to docsDevResetNow”
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
@RajkrishanS wrote:
My event log has MAC address on every line in the event log 😕
Copy and paste to a word processor program, do a search and replace to edit them out. At least the first three or last three octets.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
Connection Status
IP Address 73.XXX.XXX.XXX
2001:558:6040:2:2xxx:xxxx:xxxx:xxxx
Subnet Mask 255.255.254.0
128
Default Gateway 73.xxx.xx.x
fexx::xxx:xxxx:xxxx:xxxx
DHCP Server 0.0.0.0
DNS Server 1.1.1.1, 1.0.0.1
2001:558:feed::1, 2001:558:feed::2
Lease Obtained 3 days, 7 hours, 36 minutes, 8 seconds
Lease Expires 2 days, 22 hours, 48 minutes, 48 seconds
Release Renew Close
Time Priority Description
2024-02-18 08:15:40 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:01:5c:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:38 Notice (6) Honoring MDD; IP provisioning mode = IPv6
1970-01-01 00:00:33 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:01:5c:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:29 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:35 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:01:5c:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
2024-02-14 22:27:29 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:01:5c:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
2024-02-14 22:27:23 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:01:5c:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:34 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:30 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:01:5c:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:24 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2024-02-14 22:16:18 Critical (3) Resetting the cable modem due to docsDevResetNow
1970-01-01 00:00:28 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2024-02-14 17:01:00 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:01:5c:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
2024-02-14 17:00:53 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:01:5c:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:02:39 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:01:5c:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:02:15 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:27 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=c8:9e:43:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
The log does look bad. Tech visit is entirely appropriate.
Be sure and check your power supply cord, plugs, and etc. The CAX30 may need a firmware refresh for both sides.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
But that requested cable connection info that refused to load up
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 519000000 Hz Locked
Connectivity State OK Registration Complete
Boot State OK Operational
Security Enabled BPI+
IP Provisioning Mode Honor MDD IPv6 only
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectabables
1 Locked 256 QAM 20 519000000 Hz 4.3 dBmV 39.0 dB 0 0
2 Locked 256 QAM 4 417000000 Hz 3.3 dBmV 39.2 dB 0 0
3 Locked 256 QAM 5 423000000 Hz 3.4 dBmV 39.2 dB 0 0
4 Locked 256 QAM 6 429000000 Hz 3.7 dBmV 39.2 dB 0 0
5 Locked 256 QAM 7 435000000 Hz 3.5 dBmV 39.1 dB 0 0
6 Locked 256 QAM 8 441000000 Hz 3.2 dBmV 39.0 dB 0 0
7 Locked 256 QAM 9 447000000 Hz 3.3 dBmV 39.0 dB 0 0
8 Locked 256 QAM 10 453000000 Hz 3.5 dBmV 39.0 dB 0 0
9 Locked 256 QAM 11 459000000 Hz 3.5 dBmV 39.0 dB 0 0
10 Locked 256 QAM 12 465000000 Hz 3.8 dBmV 39.0 dB 0 0
11 Locked 256 QAM 13 471000000 Hz 3.7 dBmV 39.0 dB 0 0
12 Locked 256 QAM 14 477000000 Hz 3.7 dBmV 38.9 dB 0 0
13 Locked 256 QAM 15 483000000 Hz 3.8 dBmV 39.0 dB 0 0
14 Locked 256 QAM 16 489000000 Hz 3.7 dBmV 38.9 dB 0 0
15 Locked 256 QAM 17 495000000 Hz 3.8 dBmV 38.9 dB 0 0
16 Locked 256 QAM 18 507000000 Hz 4.0 dBmV 39.0 dB 0 0
17 Locked 256 QAM 19 513000000 Hz 4.1 dBmV 38.9 dB 0 0
18 Locked 256 QAM 21 525000000 Hz 4.2 dBmV 39.0 dB 0 0
19 Locked 256 QAM 22 531000000 Hz 4.4 dBmV 39.0 dB 0 0
20 Locked 256 QAM 23 537000000 Hz 4.6 dBmV 39.0 dB 0 0
21 Locked 256 QAM 24 543000000 Hz 4.4 dBmV 39.0 dB 0 0
22 Locked 256 QAM 25 549000000 Hz 4.8 dBmV 39.0 dB 0 0
23 Locked 256 QAM 26 555000000 Hz 4.6 dBmV 39.0 dB 0 0
24 Locked 256 QAM 27 561000000 Hz 4.9 dBmV 38.9 dB 0 0
25 Locked 256 QAM 28 567000000 Hz 4.9 dBmV 38.9 dB 0 0
26 Locked 256 QAM 29 573000000 Hz 4.9 dBmV 38.9 dB 0 0
27 Locked 256 QAM 30 579000000 Hz 5.0 dBmV 38.9 dB 0 0
28 Locked 256 QAM 31 585000000 Hz 5.1 dBmV 38.8 dB 0 0
29 Locked 256 QAM 32 591000000 Hz 4.9 dBmV 38.8 dB 0 0
30 Locked 256 QAM 33 597000000 Hz 5.2 dBmV 38.7 dB 0 0
31 Locked 256 QAM 34 603000000 Hz 4.9 dBmV 38.6 dB 0 0
32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 1 2560 Ksym/sec 10400000 Hz 44.8 dBmV
2 Locked ATDMA 2 2560 Ksym/sec 16400000 Hz 45.5 dBmV
3 Locked ATDMA 3 2560 Ksym/sec 22800000 Hz 46.3 dBmV
4 Locked ATDMA 4 2560 Ksym/sec 29200000 Hz 46.3 dBmV
5 Locked ATDMA 5 2560 Ksym/sec 35600000 Hz 46.8 dBmV
6 Locked ATDMA 6 2560 Ksym/sec 40400000 Hz 49.0 dBmV
7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV
8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV
Downstream OFDM Channels
Channel Channel ID Indicator Subcarrier Zero Frequency Active Subcarrier Number Range Total Codewords Uncorrectable Codewords
1 48 Non-Primary 629.6 MHz 1108 ~ 2987 1814561 0
2 0 Other 0 MHz 0 ~ 0 0 0
Upstream OFDMA Channels
Channel UpstreamIsMuted Ranging Status Subcarrier Zero Frequency Active Subcarrier Number Range Symbols Per Frame Tx Power
1 Other 0 MHz 0 ~ 0 0 0 dBmV
2 Other 0 MHz 0 ~ 0 0 0 dBmV
Extended Upstream Transmit Power
Current System Time: 2024-02-20 03:07:23
System Up Time: 00:10:08
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
Power levels look good:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Correctables and Un-correctables are zeros which is also good.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
Your power levels are OK, if anything they are on the high side.
Of course your correctable/uncorrecable values are zero, your device has an up time of 10 minutes! These values reset to zero when you reboot.
The modem side of your device has firmware that only your ISP can update. The router side has firmware that the user can update/refresh. Go to the downloads section at the top of this page, put in your model number and check/download the most recent router firmware.
Attempting to configure or troubleshoot a modem/gateway via a mobile device is an exercise in pure frustration. There is a real chance you cannot get there from here. If you know someone with a computer you could use, it would be very helpful.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
Firmware/Software
Firmware Version 2.2.1.12
Release Notes
NETGEAR Nighthawk App (Android)
NETGEAR Nighthawk App (iOS)
Firmware Version 1.4.12.2
Release Notes
Firmware Version 1.4.11.2
Release Notes
2.2.1.12! About to attempt this now!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
https://community.netgear.com/t5/Cable-Modems-Gateways/CAX30-Timing-Synchronization-failure-Loss-of-...
Fingers crossed that, as Xfinity loves to say, “they will find a permanent solution for this issue” Right.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
Cable Connection
Cancel Apply
Cable Diagnostic
Status: Good
Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
Internet Access:
Downstream Status:
Upstream Status:
Refresh Save Cable Diagnostic Info
Starting Frequency
Startup Procedure
Acquire Downstream Channel 417000000 Hz Locked
Connectivity State OK Operational
1 Locked 256 QAM 4 417000000 Hz 3.2 dBmV 39.2 dB 0 0
2 Locked 256 QAM 5 423000000 Hz 3.3 dBmV 39.1 dB 0 0
3 Locked 256 QAM 6 429000000 Hz 3.6 dBmV 39.2 dB 0 0
4 Locked 256 QAM 7 435000000 Hz 3.5 dBmV 39.1 dB 0 0
5 Locked 256 QAM 8 441000000 Hz 3.2 dBmV 38.9 dB 0 0
6 Locked 256 QAM 9 447000000 Hz 3.3 dBmV 38.9 dB 0 0
7 Locked 256 QAM 10 453000000 Hz 3.4 dBmV 38.9 dB 0 0
8 Locked 256 QAM 11 459000000 Hz 3.5 dBmV 39.0 dB 0 0
9 Locked 256 QAM 12 465000000 Hz 3.7 dBmV 39.0 dB 0 0
10 Locked 256 QAM 13 471000000 Hz 3.6 dBmV 38.9 dB 0 0
11 Locked 256 QAM 14 477000000 Hz 3.6 dBmV 38.9 dB 0 0
12 Locked 256 QAM 15 483000000 Hz 3.7 dBmV 38.9 dB 0 0
13 Locked 256 QAM 16 489000000 Hz 3.7 dBmV 38.9 dB 0 0
14 Locked 256 QAM 17 495000000 Hz 3.8 dBmV 38.9 dB 0 0
15 Locked 256 QAM 18 507000000 Hz 3.9 dBmV 38.9 dB 0 0
16 Locked 256 QAM 19 513000000 Hz 4.0 dBmV 38.8 dB 0 0
17 Locked 256 QAM 20 519000000 Hz 4.2 dBmV 38.9 dB 0 0
18 Locked 256 QAM 21 525000000 Hz 4.1 dBmV 38.9 dB 0 0
19 Locked 256 QAM 22 531000000 Hz 4.3 dBmV 38.9 dB 0 0
20 Locked 256 QAM 23 537000000 Hz 4.5 dBmV 38.9 dB 0 0
21 Locked 256 QAM 24 543000000 Hz 4.3 dBmV 38.8 dB 0 0
22 Locked 256 QAM 25 549000000 Hz 4.7 dBmV 38.9 dB 0 0
23 Locked 256 QAM 26 555000000 Hz 4.5 dBmV 38.8 dB 0 0
24 Locked 256 QAM 27 561000000 Hz 4.8 dBmV 38.8 dB 0 0
25 Locked 256 QAM 28 567000000 Hz 4.8 dBmV 38.8 dB 0 0
26 Locked 256 QAM 29 573000000 Hz 4.8 dBmV 38.8 dB 0 0
27 Locked 256 QAM 30 579000000 Hz 4.9 dBmV 38.8 dB 0 0
28 Locked 256 QAM 31 585000000 Hz 4.9 dBmV 38.7 dB 0 0
29 Locked 256 QAM 32 591000000 Hz 4.8 dBmV 38.6 dB 0 0
30 Locked 256 QAM 33 597000000 Hz 5.0 dBmV 38.6 dB 0 0
31 Locked 256 QAM 34 603000000 Hz 4.8 dBmV 38.5 dB 0 0
1 Locked ATDMA 1 5120 Ksym/sec 10400000 Hz 44.8 dBmV
2 Locked ATDMA 2 5120 Ksym/sec 16400000 Hz 45.8 dBmV
3 Locked ATDMA 3 5120 Ksym/sec 22800000 Hz 46.5 dBmV
4 Locked ATDMA 4 5120 Ksym/sec 29200000 Hz 46.3 dBmV
5 Locked ATDMA 5 5120 Ksym/sec 35600000 Hz 46.8 dBmV
6 Locked ATDMA 6 5120 Ksym/sec 40400000 Hz 49.3 dBmV
Channel Channel ID Frequency Power SNR/MER Active Subcarrier Number Range Total Codewords Uncorrectable Codewords
1 48 722000000 Hz 4.8 dBmV 36.1 dB 1108 ~ 2987 316011222 0
2 0 0 Hz 0 dBmV 0 dB 0 ~ 0 0 0
Current System Time: 2024-02-22 14:10:11
System Up Time: 1Days, 01:20:58
Event Log
2024-02-21 21:01:02 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=c8:9e:43:6f:0a:00;CMTS-MAC=00:01:5c:6f:82:59;CM-QOS=1.1;CM-VER=3.1;
2024-02-21 12:50:31 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=c8:9e:43:6f:0a:00;CMTS-MAC=00:01:5c:6f:82:59;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:32 Notice (6) Honoring MDD; IP provisioning mode = IPv6
1970-01-01 00:00:29 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:6f:0a:00;CMTS-MAC=00:01:5c:6f:82:59;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:24 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=c8:9e:43:6f:0a:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2024-02-21 12:25:08 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=c8:9e:43:6f:0a:00;CMTS-MAC=00:01:5c:6f:82:59;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:30 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:6f:0a:00;CMTS-MAC=00:01:5c:6f:82:59;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:02:27 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:6f:0a:00;CMTS-MAC=00:01:5c:6f:82:59;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:29 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=c8:9e:43:6f:0a:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Speed
He stated that it must be an issue with the CAX30’s switch panel however could not give any reasonable explanation as to why the wifi connection for the speed reduced device was also slow, so I dismissed what he said.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
