Orbi WiFi 7 RBE973
Reply
Nighthawk AC1900 remote access doesn't connect
TACHIT
I have successfully set up my modem for a while now and have no issues using the Android app to manage the Router locally.  However, I recently logged into the local web interface to turn on the remote access functions of the router to manage while away.  It shows that was successful.  I screen copied the IP and port info from the web interface but it will still not communicate with the router outside of the local network.  I have tried several different browsers to access it and the Android app doesn't show any choice for remote management.  Any pointers you can offer out there?
Thanks
Message 1 of 13
Accepted Solutions
TACHIT
Re: Nighthawk AC1900 remote access doesn't connect
Yep,
Thanks for the input.  I've only had it for 3 years purchased new so... welcome to the world of technology.
Message 12 of 13
All Replies
Guru
What model modem do you have? C####
NG has removed web page remote access from most of there products due to security concerns. Only way to access products is thru NGs mobile apps like Nighthawk or Orbi apps?
Message 2 of 13
TACHIT
C7000v2
Message 3 of 13
Guru
Nighthawk app you can access remotely with Anywhere Access for limited monitoring and changes.
Message 4 of 13
TACHIT
I have the Nighthawk App on my phone but there is nothing there about remote access like I've found in the manual or KB search.  My app version is 2.42.1.4373
Message 5 of 13
Guru
Under settings in the app, do you see Anywhere Access?
Message 6 of 13
TACHIT
no
Message 7 of 13
TACHIT
What is odd to me is my app seems to be a newer version that what is listed as the "latest" version on the NG site.
The latest version of the NETGEAR Nighthawk app for Android is 2.42.0.4260, released on October 12, 2024.
my version is 2.42.1.4373  running on a Google Pixel Android
Message 8 of 13
Guru
I see there is a released version on Dec 24th. And seems to be that same version.
Wondering if maybe NG removed support for the C series from the NH app. 🤔
The C series is of older generation and NG may be choosing not to support it in the NH app.
Message 9 of 13
TACHIT
Possibly,  I wonder if I can roll back my version if they even offer it any longer.  That kinda stinks if that is the case.  I'll have to build my own port tunnel with other means.
Message 10 of 13
Guru
Ya once new versions are posted, old versions are not available.
If you have a PC that is online most of the time, could install something like Teamviewer or a remote desktop app and access the modems web page that way.
Maybe time to upgrade to something newer as well.
Good Luck.
Message 11 of 13
TACHIT
Yep,
Message 12 of 13
Guru
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 583 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
