spacetoilet's avatar
spacetoilet
Nighthawk AX8 Cable Modem Router CAX80 PLEASE HELp terrible wifi speeds
I recent purchased this Modem/Router so I didn't have to rent from Comcast. I have a Gigabyte package ( I get about 940 down)
but my wifi speeds are garbage on this equipment, like mid 50's max. On 5 ghz I managed about 245 but for $425 that seems crap too, and 2 plus hours on Netgears TRASH phone support I'm at a loss what to do. The people on the phone just bounced me around all telling me the same thing, try a different Wifi channel now run the test, hard reset the device etc...
Is there something I'm missing? My default crappy comcast router that I had on my 200mbps plan at least got 140 down on 2.5ghz so what is going on? I didn't want to get the comcast Xfi Modem/router because I figured I'd pay now and save in the long run, and I checked allot of reviews on this thing saying how great it is..HELP!
  • plemans's avatar
    I've used the CAX80 and it does work great.
    I can hit around 400-500mbps over the 5g, and roughly 70-110mpbs over the 2.4ghz depending on time of day.
    What speeds do you get hardwired into it?
    Since install, did you ever try a factory reset and install?
    • spacetoilet's avatar
      spacetoilet
      I get almost 950mbps down on wired. Already factory reset, not sure what you mean by install?
      • FURRYe38's avatar
        What wifi devices are you using to speed test?
        What wireless settings are you using on the CAX
        Is Armor active on the CAX?
