- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Nighthawk CAX80 Connectivity Issues with 2018 Samsung QN55Q6FNA TV Plus
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk CAX80 Connectivity Issues with 2018 Samsung QN55Q6FNA TV Plus
The DMZ mention was to just run a quick test to see if this changed anything.
Seems that if other features are working on the TV and just the one app isn't, something with this app isn't being handled right thru the modem or there service isn't getting connected to this app. Reason for checking the DMZ. You can disable it after checking.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I too have the same exact issue and tried the same things you did as well. I have two Samsung TV's that TVplus don't work (NU7100 and Q60r). Hopefully netgear gets enough complaints about this and updates their firmware. My phones hotspot and neighbors Wifi make TVplus work fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Someting to make contact with NG support about. Doesn't seem like theres anything we can do here in the forums and needs to be addressed by NG.
Good Luck.
@brsox88 wrote:I too have the same exact issue and tried the same things you did as well. I have two Samsung TV's that TVplus don't work (NU7100 and Q60r). Hopefully netgear gets enough complaints about this and updates their firmware. My phones hotspot and neighbors Wifi make TVplus work fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you try this: Hold down the power button on the remote until unit starts to reboot. After reboot you will have to go through the setup to reconnect to your wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How can we do this if Netgear doesn't provide a way to get in contact with them. I've never seen a company with such poor communication options.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can start here:
https://www.netgear.com/support/#
and or contact a forum moderator as well. This is a holiday and weekend so best would be to make contact Sunday evenng or early Monday. Good Luck.
@brsox88 wrote:How can we do this if Netgear doesn't provide a way to get in contact with them. I've never seen a company with such poor communication options.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update: I switched to my providers modem/router as it was only $5/month. Issue was resolved immediately. So it seems Netgear needs to fix the firmware to be compatible with many Samsung TV's. They should also find a better support solution as 90 days is unrealistic. And then not be able to contact them for regarding a bug just adds to more frustrated customers and negativity toward their brand. I'll be selling my $500 CAX80, there are just too many other companies out there with better support and products.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi!
I actually am having the same issue - both Plex and Samsung TV Plus apps cannot load the streamed content from my Samsung Q90 TV.
Here's what I've tried:
Wifi, Unsecured Wifi, Ethernet, Disabling AX, and even put a managed switch between the TV and the Router.
Interesting enough -- if I do a full reset of the TV or the modem, whatever channel was left on the Samsung TV Plus starts to play. But as soon as I change the channel or go back to that channel, it can't load the content again. It seems to be blocking it somewhere, but there's nothing in the logs that can help me determine this.
I've swapped out my router with a junk old router, things work fine. So it's not the ISP either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
anyone has solution for this connectivity issue between Samsung Tvplus and CAX 80
@Paul__G wrote:I have also posted this to Samsung community boards because at the moment I'm still not sure who owns this issue!
To start off this long winded explanation of a problem I will say I have a 2018 Samsung QN55Q6FNA QLED TV that performed all functions as expected until I upgraded my router/modem.
I was previously using Optimum's Modem Arris TM1602 and Optimum's Router Sagemcom F@st 5260CV and all services were working fine on my TV. I upgraded to the brand new Netgear Nighthawk CAX80 and when I connected my TV to the network, Samsung's autoinstalled app TV Plus stopped working. All channels appear in the channel guide and are selectable but when I select a channel it does not load and instead provides an error message "Error. There was a problem while trying to play the TV PLUS channel. Check your network settings or try again later." I must specify ALL other internet connected apps have been working as usual (Netflix, Hulu, Amazon Video, etc.), only TV Plus is encountering this issue.
In terms of troubleshooting the TV, I've tried everything I could think of including: Upgrading Firmware (current T-KTM2AKUC-1294.1, BT-S), resetting network connection, using wired connection, using wireless connection (only 2 feet away from router), auto scanning channels again, turning off IPv6, power cycling TV, unplugging/plugging back in TV, signing in/out of Samsung Account, Resetting Smart Hub and ultimately doing a factory reset. However, I did try connecting the TV to my phone, using my phone as a hotspot and boom! TV Plus started working again. Then, I connect it back to the router and TV Plus goes offline again.
These steps led me to believe for sure it is a router issue somehow blocking access to TV Plus. That is until I remembered I have a 2016 Samsung UN43KU6300 that I rarely use for streaming purposes. I figured let me give TV Plus a shot on the older TV. Using the same wireless connection, to my surprise, TV Plus started working on my 2016 TV, running on software version 1242. A quick note about that 2016 TV is that it had been acting up ever since my house was struck by lightning (2018) while it was powered on, frying the main board. I had managed to obtain a new main board, pop the covers off and replace the fried board to successfully revive the TV but still things sometimes act up a bit. Besides the point, my thought now is that the newer software version 1294 is somehow not compatible with my router in terms of TV Plus but the older version is. Is there a way I can downgrade my 2018 TV's version to match the 2016 TV, flash drive side loading perhaps? Or can I bypass some type of restriction on the router that was blocking a certain communication my 2018 TV was asking for?
It is also worth noting my old modem Arris TM1602 was using the DOCSIS3.0 protocol while the new router/modem combo uses the DOCSIS3.1 protocol.
I have been in contact with Samsung Experts who have taken remote control of the TV and after 50+ minutes came up with the conclusion that it must be the Modem/Router causing the issue (since it worked on my mobile hotspot) and redirected me to my Modem/Router Supplier, Netgear . I then contacted Netgear Experts to tell them everything I had learned only for them to tell me it must be a TV issue (since the 2016 TV connected to the same network) and they redirected me back to Samsung. I fear I will be in this Ping Pong of deflections for eternity which is why I came to this message board.
If anyone has any knowledge or information please share. I am an engineer and a perfectionist and it's eating away at me not knowing the solution to this problem! Thank you all who have read this far!
- Mark as New
- Bookmark
- Subscribe
- Permalink
The solution is to use a different router, Samsung and Netgear have yet to come out with a firmware update that addresses this issue. It's most likely some imcompatibility since the CAX 80 is so new compared to these older TV's.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You probably tried this but, I have seen it before on some TV's. Set Static DNS in you device ie. TV. 8.8.8.8 and 8.8.4.4. I also had it twice to where NTP was not passing to TV. Ron
- « Previous
- 1
- 2
- Next »
