Orbi WiFi 7 RBE973
Reply
Nighthawk c7000v2 connection drops with Palo alto Global Protect
krajthilak2
Tutor
Hello,
I recently purchased Nighthawk c7000v2 and I use Global Protect vpn for my home office connectivity. This setup was working fine for couple of weeks and now all of a sudden, I can see connection drops every few minutes. I did a recurring ping to google.com to see and for every 20 successful pings I can see 10 time outs. I have maintained static IP for Primary and Secondary DNS and it did not help. Any insights on how to resolve this would be welcome. Thanks in advance !!
Message 1 of 5
Accepted Solutions
krajthilak2
Tutor
Re: Nighthawk c7000v2 connection drops with Palo alto Global Protect
Thanks for the response. I think the issue got fixed today morning after I had a call with NetGear support. They asked me to change the static IP address of DNS (Primary, secondary and tertiary) to a different one and so far it has remained stable. I will monitor this further and update the post.
Message 3 of 5
All Replies
Guru
do you have a screensnip of the cable connections page and event logs?
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
Message 2 of 5
krajthilak2
Tutor
Message 3 of 5
krajthilak2
Tutor
Issue is now resolved with the fix mentioned in previous reply.
Message 4 of 5
Guru
You can mark it solved then if you'd like
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1611 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
