- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
OpenVPN 2.5.4 Configuration Problems on Orbi CBR750
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I am running an Orbi CBR750, firmware V4.6.3.6_2.0.48 with OpenVPN 2.5.4 installed on a Windows 10 machine. When I run OpenVPN, I get these error messages:
Wed Oct 20 20:33:30 2021 WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
Wed Oct 20 20:33:30 2021 DEPRECATED OPTION: --cipher set to 'AES-128-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-128-CBC' to --data-ciphers or change --cipher 'AES-128-CBC' to --data-ciphers-fallback 'AES-128-CBC' to silence this warning.
Wed Oct 20 20:33:30 2021 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Wed Oct 20 20:33:32 2021 OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options
Wed Oct 20 20:33:32 2021 OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.1.0
Wed Oct 20 20:33:37 2021 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
I am trying to install certificate-based authentication for OpenVPN, and then have every device on my network protected without having to install the VPN client on each and every device.
I would be very grateful for any help the community can offer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OpenVPN 2.5.4 Configuration Problems on Orbi CBR750
Netgear has set up a community forum specifically for the Orbi With Cable Modem products. Most of the people who watch that forum are more likely to have experience with Orbi with cable modem and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
