- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Opening Nat types for PS4 2017
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to open my NAT type but I dont even have the option to change the type. I have followed the instructions but I dont have the option to change it. I followed the instructions @ https://kb.netgear.com/23020.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Opening Nat types for PS4 2017
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you do not see it then yours doesn't have it.
If your NAT is still strict verify if you can get it working without a router.
You might have a double NAT issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you try playing without using the router?
What's the brand and model of your modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Right, I understand that but I want to see if it's the same if you'll play it without a router.
As far as the router is concerned, you can do Port Forwarding or try use DMZ.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does your modem have a router built into it? If yes, then you have double NAT and no amount of port forwarding on the Netgear is going to work. You either need to enable bridge mode on the modem or convert your Netgear into an Access Point. This will eliminate double NAT. Then you can focus on setting up port forwarding on whichever device is functioning as a router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This device does not allow me to go into bridge mode also.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It doesn't allow me to turn it into an acess point either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its a N600 wifi Cable Modem Router
model c3700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I didn't realize that you have a cable modem/router. I don't always pay attention to which board I'm reading. My bad.
The easiest thing to do is to go to ADVANCED > Advanced Setup > UPnP and turn on UPnP. This is basically automatic port forwarding. You should also go to ADVANCED > Setup > LAN Setup and assign an IP address to your PS4 to keep it from changing. Some people consider UPnP unsafe, so caveat emptor.
An alternatively, configure port forwarding manually under ADVANCED > Advanced Setup > Port Forwarding/Port Triggering. You'll have to find out which port to forward for each game.
The last option is to put the PS4 in the router's DMZ. The picture you posted shows the DMZ Server setting. You would enter the IP address of your PS4, there. As with UPnP, you should to go ADVANCED > Setup > LAN Setup and assign an IP address to your PS4. Using the DMZ can also be considered unsafe for your PS4 since it will be unprotected by your router's firewall.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
