- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Orbi CBR750 drop connection wan side
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi CBR750 drop connection wan side
Well I have Spectrum Modem in connected direct to the Coax cable no attinuators between. It is running good getting 930Mbps speed and unable to see any errors or critical errors since it is their modem.
So at this point it was a lot of time and no final resolution and my Orbi sitting on a shelf now.
I appreciate the help and did learn something.
If I get any drops in service I will respond down the road, but for now just going to be Idle.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What brand model# modem are you using?
Could use the TP Link router as a router, disable it's wifi radios and then configure the CBR for faux AP mode and connect it to the TP Link router using one of the CBRs LAN ports. Then connect up any RBS to the CBR.
Otherwise, ya, let it run.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router I just bought is a TP Link AX1800
I can only access and login to the TP Link.
The Spectrum modem I do not think there is a way to login to that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya modems do have web pages.
Just a suggestion if you wanted to continue to use the CBR system for wireless abilities.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the CBR system? Bad with abbreviations. Is that the Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had already tried using the Orbi Modem/Router with the Spectrum Modem and it did not seem to work.
That is why I bought the TP Link
- Mark as New
- Bookmark
- Subscribe
- Permalink
For the faux AP mode on the CBR, you'll need the TP Link router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok thanks. Might try it but don't need it. I wish Spectrum would of just let me send the log I had on the Orbi on critical errors it would of made things so much easier.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should send it anyways. Seems like the Event logs read out would be same as other branded modems since the modem side is all DOCSIS information and diagnostics.
Maybe at some point put the CBR back ON and check it. Other wise, good luck.
- « Previous
- 1
- 2
- Next »
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
