- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RMA Return
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RMA Return
How did you solve the problem? It seems that I also encounter similar problem with USPS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RMA Return
Please contact NG support again or try a forum moderator.
@TrumpKing wrote:How did you solve the problem? It seems that I also encounter similar problem with USPS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RMA Return
I honestly simply hoped that the next delivery attempt would work and if it didn't then I would have thought of contacting Netgear for some sort of compensation since it wouldnt have been my fault. Luckily the next delivery attempt did work and about two days later they processed my rma and all was well. I hope the same happens to you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RMA Return
Glad you got this resolved. Thank you for letting us know.
@MrPlebbian wrote:I honestly simply hoped that the next delivery attempt would work and if it didn't then I would have thought of contacting Netgear for some sort of compensation since it wouldnt have been my fault. Luckily the next delivery attempt did work and about two days later they processed my rma and all was well. I hope the same happens to you!
