Orbi WiFi 7 RBE973
Reply
Re: Nighthawk CAX80 login loop
jsomaini
I have the same issue.  When trying to authenticate to the web service (on the router), it forces a reauthentication.  Eventually, it asks for the serial number to reset the pw.  Even after doing that, it still has the same issue.  I've rebooted multiple times, verified the password is correct etc, etc...
No idea what the issue is.
Message 1 of 5
Guru
What browser are you using? Try a different browser, MS Edge, Firefox or Opera.
Be sure to clear out all browser caches before navigating to the modems web page.
Has a factory reset and setup from scratch been performed since last update?
Message 2 of 5
Guru
have you made sure the password meets these requirements?
10 characters with at least:
1 special character
1 upper case
1 lower case
1 number
Message 3 of 5
jsomaini
Re: Unable to reset router password on CAX80
How can you backup the config if you can't log into the web interface?  (hence the issue we are having).
Thanks
Message 4 of 5
Guru
Please give feedback to the questions presented.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 533 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
