Orbi WiFi 7 RBE973
Reply
Remote boot for C7100V – Nighthawk AC1900 WiFi Cable Modem Router
SP7760
Follower
How can I reboot my router when away from home?
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 3
Guru
Re: Remote boot for C7100V – Nighthawk AC1900 WiFi Cable Modem Router
Got a computer with teamview or another remote access program? If so, you can log into that and then connect the the c7100v through the browser and reboot. Or some ISP's have a reboot option on their own portal to trigger a reboot. I know xfinity has that option.
Message 2 of 3
The C7100V supports the Nighthawk app. A remote reboot is one of the things the app can manage.
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
This means that you can set it up to support Anywhere Access.
How do I enable or disable Anywhere Access on my router using the Nighthawk app? | Answer | NETGEAR ...
You can read up on how to use this by checking the bit in the manual on Remote Management.
Remote Management is now Anywhere Access in the Nighthawk and Orbi apps | Answer | NETGEAR Support
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 792 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
