- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Security questions I never set up
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Security questions I never set up
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to using a web browser and walk thru the setup wizard. This time setup the security questions and write down all important information for safe keeping later on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@areolata wrote:
my only thought was that they were pulled from my netgear or xfinity account, this router shows as linked/ registered on both, but I do not find any such questions on either account.
There is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct. So, nothing left over from something else, or picked up from your ISP.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Netgear is making life increasingly difficult by changing the security to force you to set up password recovery. That is probably why it automatically asks those password recovery questions.
Another problem is that Netgear now wants us to use the mobile "app" to set up and control devices.
See if you can get in through this route:
or
http://192.168.0.1/adv_index.htm
Another thing to try is the Netgear genie for your operating system.
genie | Product | Support | NETGEAR
That's a useful thing to have around anyway.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@michaelkenward Unfortunately your two links do not work for me (file not found errors). And I installed the genie but it does not accept "password" as the password the same as the nighthawk app (both say login failed; please check password). However I can use "password" to log in directly to the modem from Chrome (bypassing Netgear apps) but then I encounter the two security questions. I have already done factory resets 3 times and it would not clear those questions when trying via desktop nor did the resets fix my inability to use the admin/password credentials on the nighthawk app. I will try few more factory resets and see if it makes any difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there anything else on the network?
I assume that you have tried different browsers.
Have you tried accessing the modem/router without an Internet connection? You do not need this to change many settings on the device.
I doubt if more resets will get you anywhere. As this is a new device, I would return it to the seller for a replacement.
That's odd. I would expect a the usual "page not found" or some other error. File not found makes no sense because that's not what the browser is looking for.
You talked earlier of "my Netgear account". Where did that come from? You don't need any account to get a device to work.
