- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Showing Unidentified network- public network on C7000v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
No wired internet and shows Unidentified Network- Public network... NVIDIA Network Controller... No other network controller found and can not switch over.. WIFI works great, just nothing hardwired
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Showing Unidentified network- public network on C7000v2
This on a PC?
Please provide a screen shot of this?
This is usually a Windows networking issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something i the configuration of your PCs networking.
Check LAN cables as well.
Ensure your network configuration on the PCs is set for auto obtain IP addressing.
Contact MS for networking support if using Windows.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have reset all connections, replaced all cables. Geni also reports that WAN is up but LAN in down on all ports... Worked great for the 8 or so months i've had it. But around May 26, no hardwire connection. WiFi working perfect... Myself and 2 other guys are turning our heads inside out trying to figure.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have a spare external router that you can put online. You need to bridge the C7000 modem/router so it's just a modem, then connect a external router and everything to this router to see if you still notice the same problem or not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now thats something i hadn't thought of... I'll check on the other router and if so i'll do this and let you kno2w... Much appreciation
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well that was a bust... Older modem won't load on windows 10... Looking for specific LAN driver update to see if that may well be the problem also. Installing new Windows 10 update (1903) at the moment that was downloaded for me and put on a CD... Will keep you updated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Older modem? What is the model of this modem?
Modems don't need drivers. Just a LAN connection to the modem if it has a management web page. Were looking for the other router that you have. Or is the other router a modem/router combo as well?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Older Modem/Router. Motorola SurfboardeXtreme...SBG6580... Used it until I upgraded to windows 10 and it wouldn't connect... Tried installing software this morning, system said it needed Acrobat Air to install... Would not install this. Went on site but AIR driver won't install.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You only need a LAN cable connection with that modem with ur PC. I presume your PC has a LAN adapter?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lan interface but no software adapter is showing up when I go to change adapters from public... Reason I was looking up the driver to begin with...LOL
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. LOL. Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks... Think I'm gonna need it...LOL
- Mark as New
- Bookmark
- Subscribe
- Permalink
