Orbi WiFi 7 RBE973
Reply
Simulated Sine Wave UPS?
edpnw
Hello -- In buying a new UPS for my C7800 WiFi Cable Modem Router, I'm wondering if I can get by with a cheaper simulated sine wave UPS or if I should buy a full sine wave UPS. Or, for that matter, even a super-cheap step wave unit. I believe it depends on the kind of power supply used by the router but I don't have the knowledge or background to understand these things. Thank you!
Message 1 of 4
Accepted Solutions
Guru
Re: Simulated Sine Wave UPS?
I would think any good quality UPS that provides power specs for the modem should work. APS makes good quality UPS.
Message 2 of 4
All Replies
Guru
Message 2 of 4
edpnw
First, thank you.
Second, I've no clue of the way things are done here. Is it proper to thank you in this forum? Do people just ignore responses and go along their day?
Message 3 of 4
Guru
Yes of course. It's up to people to respond to posts.
Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1156 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
