Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Splitters and signal levels
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-19
03:21 AM
2020-09-19
03:21 AM
https://ibb.co/0FXFvps
https://ibb.co/T88nBkB
Recommended downstream power levels are -7 dbmv to +7 dbmv
Recommended upstream power levels are
35 dbmv to 49 dbmv
(Modem manufacturer, Arris, recommends 45 dbmv to 51 dbmv)
I have a necessary splitter that splits to my cable modem and to my tv.
Even after that split, my downstream power levels are peaking at 7+ dbmv and my upstream are below manufacturer recommendation.
I decided to see what the levels looked like after adding an additional splitter and it actually makes my levels more in the median of where I want them.
My question is: Should I leave it there, or do you think I'd be prone to problems?
Ps: these screemshots are my Arris SB8200, but I also have a Netgear Cm1000.
Same situation applies.
Thanks in advance!
35 dbmv to 49 dbmv
Thanks in advance!
Model: CM1000|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-19
05:00 AM
2020-09-19
05:00 AM
Re: Splitters and signal levels
Are you having issues?
Either one looks decent. You don't have errors.
If you're loosing speeds/packets/or having drops, then I'd have the isp check the line but otherwise it looks fine.
Message 2 of 2
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
