- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Use Netgear C3700 N600 as Modem Only
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello! I am planning to upgrade to a different wifi router in the future. Can I use this modem/router as a modem only and connect a router to it? Thanks!
I heard that the C3700/N300 doesen't, but i'm wondering if the C3700/N600 does.
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
When the C3700 is fully bridged, then the R6700 router will work with it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Use Netgear C3700 N600 as Modem Only
I would review the user manual to see if there is any bridge mode or modem mode or disable NAT mode features for this modem combo. Most modem combo supports modem only mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] C3700 [...]
C3700 or C3700v2? Look at the product label.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Look for "Cable Your
Modem Router to a Router or Gateway".
> C3700/N600 does.
I don't know what you heard where, but I don't see any "C3700/N300"
at "http://netgear.com/support".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe I should rephrase a bit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
