Orbi WiFi 7 RBE973
Reply
Wifi disconnect when Imac sleeps Nighthawk AC1900 C7000
Dmesk
Hi. i recently changed from an older Netgear modem to a Netgear Nighthawk ac1900 Nbn modem/router. Now every time i wake or start the imac, i need to choose the network and enter the password again. ive been into network settings and deleted any unused networks etc.
Any help would be great, Thanks.
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 5
antinode
Guru
Re: Wifi disconnect when Imac sleeps Nighthawk AC1900 C7000
> [...] recently changed from an older Netgear modem [...]
   Model?
> [...] to a Netgear Nighthawk ac1900 Nbn modem/router. [...]
   Is that accurate?
> [...] Now every time i wake or start the imac, i need to choose the
   And what did you see there?  What are the settings at System
Preferences > Network > Advanced... > Wi-Fi ?
      Preferred Networks?
      Remember networks [...]?
> [...] and deleted any unused networks etc.
   What, exactly, does "etc" mean to you?  Have you removed and replaced
your desired SSID?  If you can connect manually, but the computer
doesn't connect automatically, then I'd expect the problem to be with
the computer, not the router.
Message 2 of 5
Dmesk
Hi Antinode
i though the etc would would get m into trouble, sorry. 🙂 No i didt delete any other settings. i just followed info i found online regarding System pref, Network, Advanced, then deleting any old networks.
When i turn on or wake the computer i have to select my wifi network and put in the password evey time. ive tried with and without selecting remember this network when logiging in. restarted the computer.
im running Sierra 10.13.6.
Screen Shot 2019-02-21 at 8.26.24 am.pngScreen Shot 2019-02-21 at 8.26.34 am.png
Message 3 of 5
antinode
Guru
> [...] i just followed info i found online [...]
   With my weak psychic powers, that detail-free non-description conveys
no useful information.
> [...] Have you removed and replaced your desired SSID? [...]
   Still wondering.  This whole Q&A thing typically works better if you
actually answer the questions.  Look for "?".
   In-line images in these forums must wait for moderator approval, so I
can't see yours yet.  (An attached file incurs no such delay.)  Some
little description would be nice, even if the pictures were visible.
Message 4 of 5
Dmesk
Sorry. im not a computer wiz. i tried my best to explain something i thought might have a pretty simple explanation. ill take it somewhere else.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1164 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
