Orbi WiFi 7 RBE973
Reply
Wired Router for CM1200
JWY-Leucadia
Tutor
Does Netgear make a WIRED (not WiFi) router that works with the CM1200?  If not, can anyone recommend another brand & model?  I already have an Orbi WiFi router but for various reasons it can't be located near my CM1200 cable modem so I need a wired (gigabit) router to attach directly to my CM1200.
Thanks in advance for any recommendations.
Model: CM1200|Nighthawk Multi-Gig Speed Cable Modem
Message 1 of 8
Accepted Solutions
Guru
Re: Wired Router for CM1200
Sorry I surely didn't look closer are your question.
Not that I can tell:
https://store.netgear.com/home/?lang=en_US&_ga=2.37360672.1499443964.1586975252-197904915.1586975252
Most routers include wifi now days. Most R, XR and RAX series routers have built in wifi radios that can be disabled if wifi isn't needed.
Other suggestion would be to maybe go with wired FIREWALL appliance device. These have some router features and good for firewall and usually don't have wifi radios built in.
Or go with Ubiquity routers. Edge X router doesn't have wifi. Wired only. I have one.
Message 4 of 8
All Replies
Guru
NG Orbi MESH, R, XR or RAX series routers all work with the CM modem. Just pick something that best suites your needs.
Message 2 of 8
JWY-Leucadia
Tutor
Thanks FURRYe38 but aren't all of these WiFi routers?  I'm specifically looking for a WIRED router.
Message 3 of 8
Guru
Message 4 of 8
Guru
I've heard good things about the edge router's but haven't tried one yet. It'd be a good route to go if you're looking for one without wifi.
Message 5 of 8
Guru
Unfortunately the X doesn't do any WAN to LAN speeds over 300Mbps. Smiley Sad
Message 6 of 8
JWY-Leucadia
Tutor
Thanks to both of you.  I think I'll try Ubiquiti EdgeRouter X
Message 7 of 8
Guru
Good Luck
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2013 views
  • 7 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
